[ROM+Kernel][CM-11.0][4.4.4][OS2SD/internal][f2fs]bigsuperROM-thunderc-4.4.4
Any advice for when I go in on Monday to work on this bad boy? I feel it in my bones that this'll be the time.
ok. I reformatted one over for the 'last stable' as a good testpoint.
the 6/28 is corrupted on Drive.
I guess use the 10/25.
in twrp, instead of just wiping data, do repair or change filesystem under wipe>data. change to ext4 or repair if already ext4. hopefully that will fix it.
same for system.
then install the cm11 20141025, newest pa_gapps_modular_pico, pa_facilitator-pico-4.4.4-2014-1114, Sprint-fix, and if you want, VoiceSearchPowerButton mod.
in that order.
reboot system.
hopefully, enjoy.
the sprint-fix was borked, wouldn't chmod /system/build.prop; which is basically death-on-a-stick.
so,
Oh wow...does Browser need /cache too? That's now acting dumb and not working...
you can use more recent 1025 too, redownload the sprint-fix, and hopefully your /cache woes will vanish.
Also, when should I flash the ZVJ ZVD fix?
I'm on ZVJ radio.
Update
Reinstalled TWRP, went to repair data and system, it seems like it does something, but it still is unable to mount.
Is there some way to look at my partitions through the data cable? Sort of like a partition manager for android? Or is this it-on the recovery?
I'm on ZVJ radio.
Update
zvj patch after sprint fix or thereabouts I figure.
you might want to repartition the sd card with that twrp, it's the brute-force method to fix it.
adb shell mount, adb shell ls /dev/block (looking for mmcblk0p2-p4) and such for the cable.
I remember that ext2 won't Mount in recovery without using busybox in the shell.
selinux permissions problem with ext2 in the kernel, sorry.
you'll have to use an older version than the ext2 unless you want to modify the updater-script to use busybox to Mount.
when you say
I checked, and the SD card did in fact partition correctly.
I'm referring to the internal partitions of /data and /system
So with adb connected on the cable, the commands listed will allow me to look at the internal partitions?
when you say
oops. those are os2sd.
you want /dev/block/mtdblock5 and 6 for internal.
busybox mount /dev/block/mtdblock5 /data
busybox mount /dev/block/mtdblock6 /system
reverse /system and /data coming from legacy ROM or pre-tls. (august or so)
I think I just confused you further. Lemme try that again.
So I am installing the OS2SD version. But on wiping the old rom (Slimrom) (factory reset) it states "cannot mount /system" and "cannot mount /data". In other words, the actual partitions of the phone (not the SD) seem to not want to mount in order to be wiped. Also, In TWRP, it will fail if I go into "Mounts" and try to mount the system and the data. I did also try to do the "format to ext4" on both, it seemed like it didn't work (though it didn't say "failed"), it blanked out and went to the recovery lock screen
Now a little diagnostic on the Recovery, when I go back to Slim, and load up COT v2.1, it will mount system and data fine, as well as wipe/format both of them.
(UPDATE)
Okay, so when I switch to internal mode, the system and data partitions (inside the phone) can now mount and wipe. It's only in OS2SD mode that it doesn't mount/wipe.
Very odd. I'll update more as the day goes on.
(2nd UPDATE)
I found I was able to format
(UPDATE)
you can actually backup your internal /boot partition and not wipe either internal partition before installing os2sd. if you want to revert to your current internal that way you just restore /boot from it.
I don't understand why its uppity about the os2sd partitions though.
really need to get vnc set up on my evo, so i can work on this stuff at work on days like this one. not much to do here, could better spend my time debugging and coding instead of browsing and searching.
(UPDATE)
by the way, can you post your recovery.log? /tmp/recovery.log or under advanced, copy log to sd card.
then I can get more specifics about the issue you're getting.
Haha, yeah I work on the phone during my second job. It's an online web conference job, so I spend half the time listening to tech support work with the other half of the web conference.
I'll redo the install work and check out the copy log to SD, probably Monday, maybe tomorrow.
UPDATE
Also, I noticed that I think the /system says yaffs2 for file format, and the /data says auto for file format. Dunno if that's working. Also, I got system straightened out through internal mode, then going to OS2SD, it mounts fine. It's down to just data that's being a PITA.
well, bright side, data only used for eri.xml (carrier id text says sprint instead of virgin mobile) on fresh install, and partitioning formats it to ext4.
the bootloop you were getting was from bad sprint fix, redownload it if you've not already.
guess i need to reexamine that twrp, my onboard versions vary.
Hmm. Last night I rebooted into recovery just for the hell of it...and /cache was already mounted there. Bizarre. Yeaaaaaaaah, I think I'll get that 10/25 stuff and just start over from there, lmao!!
Oh!! You kinda goofed on the link - it went to the download page for the 10/25 *checksum*, not the ROM itself.
...I'll pass on the Voice Search Power Button mod, I don't use that anyway (and that's usually the first thing to go via TB).
link fixed.
Okay, here's the log
__bionic_open_tzdata: couldn't find any tzdata when looking for localtime!
__bionic_open_tzdata: couldn't find any tzdata when looking for GMT!
__bionic_open_tzdata: couldn't find any tzdata when looking for posixrules!
Starting TWRP 2.8.0.0 on Sun Jan 4 23:16:11 2015
I:=> hardware id from cpuinfo: 'THUNDER Sprint board (LGE LS67'
I:=> serial from cpuinfo: '0000000000000000'
I:Single storage only.
I:No internal storage defined.
I:No storage defined, defaulting to /sdcard.
TW_POWER_BUTTON := 107
I:Lun file '/sys/class/android_usb/android0/f_mass_storage/lun/file'
I:TW_BRIGHTNESS_PATH := /sys/class/leds/lcd-backlight/brightness
I:Found brightness file at '/sys/class/leds/lcd-backlight/brightness'
I:TWFunc::Set_Brightness: Setting brightness control to 255
I:TW_EXCLUDE_ENCRYPTED_BACKUPS := true
I:Copying file /etc/twrp_sd.fstab to /cache/recovery/recovery.fstab
I:Copying file /etc/twrp_sd.fstab to /etc/recovery.fstab
I:Copying file /etc/twrp_sd.fstab to /etc/twrp.fstab
=> Processing recovery.fstab
I:Processing '/boot'
I:Processing '/cache'
I:Processing '/data'
I:Processing '/misc'
I:Processing '/recovery'
I:Processing '/system'
I:Processing '/sdcard'
I:Creating Android Secure: /sdcard/.android_secure
I:Backup folder set to '/sdcard/TWRP/BACKUPS/0000000000000000'
I:Settings storage is '/sdcard'
Updating partition details...
E:Unable to mount '/data'
I:Actual block device: '', current file system: 'auto'
I:Unmounting main partitions...
Partition Logs:
/boot | /dev/block/mtdblock0 | Size: 7MB
Flags: Can_Be_Backed_Up IsPresent
Primary_Block_Device: /dev/block/mtdblock0
Display_Name: Boot
Storage_Name: boot
Backup_Path: /boot
Backup_Name: boot
Backup_Display_Name: Boot
Storage_Path: /boot
Current_File_System: mtd
Fstab_File_System: mtd
MTD_Name: boot
Backup_Method: flash_utils
/cache | /dev/block/mtdblock1 | Size: 124MB Used: 1MB Free: 122MB Backup Size: 1MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI IsPresent
Primary_Block_Device: /dev/block/mtdblock1
Display_Name: Cache
Storage_Name: Cache
Backup_Path: /cache
Backup_Name: cache
Backup_Display_Name: Cache
Storage_Path: /cache
Current_File_System: yaffs2
Fstab_File_System: yaffs2
MTD_Name: cache
Backup_Method: files
/data | | Size: 0MB Used: 0MB Free: 0MB Backup Size: 0MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI Can_Encrypt_Backup Use_Userdata_Encryption
Primary_Block_Device: /dev/block/mmcblk0p4
Display_Name: Data
Storage_Name: Data
Backup_Path: /data
Backup_Name: data
Backup_Display_Name: Data
Storage_Path: /data
Current_File_System: auto
Fstab_File_System: auto
/misc | /dev/block/mtdblock7 | Size: 0MB
Flags: IsPresent
Primary_Block_Device: /dev/block/mtdblock7
Display_Name: misc
Storage_Name: misc
Backup_Path: /misc
Backup_Name: misc
Backup_Display_Name: misc
Storage_Path: /misc
MTD_Name: misc
/recovery | /dev/block/mtdblock2 | Size: 7MB
Flags: IsPresent
Primary_Block_Device: /dev/block/mtdblock2
Display_Name: Recovery
Storage_Name: recovery
Backup_Path: /recovery
Backup_Name: recovery
Backup_Display_Name: Recovery
Storage_Path: /recovery
MTD_Name: recovery
/system | /dev/block/mmcblk0p2 | Size: 1922MB Used: 154MB Free: 1767MB Backup Size: 154MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_Available_in_GUI IsPresent
Primary_Block_Device: /dev/block/mmcblk0p2
Display_Name: System
Storage_Name: System
Backup_Path: /system
Backup_Name: system
Backup_Display_Name: System
Storage_Path: /system
Current_File_System: ext4
/sdcard | /dev/block/mmcblk0p1 | Size: 5554MB Used: 351MB Free: 5203MB Backup Size: 13MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_Available_in_GUI Removable IsPresent Has_Android_Secure Is_Storage
Symlink_Path: /sdcard/.android_secure
Symlink_Mount_Point: /and-sec
Primary_Block_Device: /dev/block/mmcblk0p1
Display_Name: SD Card
Storage_Name: SD Card
Backup_Path: /and-sec
Backup_Name: and-sec
Backup_Display_Name: Android Secure
Storage_Path: /sdcard
Current_File_System: vfat
Fstab_File_System: vfat
Starting the UI...Pixel format: 320x480 @ 16bpp
Pixel format: RGB_565
Not using qualcomm overlay, 'msmfb30_1000a'
framebuffer: fd 4 (320 x 480)
=> Linking mtab
Renaming regular /etc/recovery.fstab -> /etc/recovery.fstab.bak
Moving /etc/twrp.fstab -> /etc/recovery.fstab
Partition Logs:
Display_Name: Boot
Storage_Name: boot
Backup_Path: /boot
Backup_Name: boot
Storage_Path: /boot
MTD_Name: boot
Display_Name: Cache
Storage_Name: Cache
Backup_Path: /cache
Backup_Name: cache
MTD_Name: cache
Display_Name: Data
Storage_Name: Data
Backup_Path: /data
Backup_Name: data
Storage_Path: /data
Flags: IsPresent
Display_Name: misc
Storage_Name: misc
Backup_Path: /misc
Backup_Name: misc
Storage_Path: /misc
MTD_Name: misc
Flags: IsPresent
MTD_Name: recovery
Backup_Name: system
I:Loading package: TWRP (/script/ui.xml)
I:Loading package: TWRP (/sdcard/TWRP/theme/ui.zip)
I:Loading package: TWRP (/res/ui.xml)
I:Loading resources...
I:Loading variables...
I:Loading mouse cursor...
I:Loading pages...
I:PageSet::CheckInclude loading filename: ''
I:Loading included resources...
I:Loading included variables...
I:Loading included pages...
I:Loading page main
I:Loading page main2
I:Loading page install
I:Loading page flash_confirm
I:Loading page flash_zip
I:Loading page flash_done
I:Loading page clear_vars
I:Loading page confirm_action
I:Loading page action_page
I:Loading page singleaction_page
I:Loading page action_complete
I:Loading page filecheck
I:Loading page rebootcheck
I:Loading page wipe
I:Loading page advancedwipe
I:Loading page formatdata
I:Loading page formatdata_confirm
I:Loading page checkpartitionlist
I:Loading page partitionoptions
I:Loading page refreshfilesystem
I:Loading page selectfilesystem
I:Loading page backup
I:Loading page backupname1
I:Loading page backupname2
I:Loading page backupencryption
I:Loading page backupencryption2
I:Loading page checkbackuppassword
I:Loading page backup_run
I:Loading page restore
I:Loading page restore_read
I:Loading page restore_decrypt
I:Loading page try_restore_decrypt
I:Loading page restore_select
I:Loading page renamebackup
I:Loading page restore_run
I:Loading page selectstorage
I:Loading page mount
I:Loading page usb_mount
I:Loading page usb_umount
I:Loading page settings
I:Loading page timezone
I:Loading page screen
I:Loading page Vibrate
I:Loading page partsdcard
I:Loading page htcdumlock
I:Loading page lock
I:Loading page filemanagerlist
I:Loading page filemanageroptions
I:Loading page choosedestinationfolder
I:Loading page filemanagerrenamefile
I:Loading page filemanagerrenamefolder
I:Loading page filemanagerchmod
I:Loading page filemanagerconfirm
I:Loading page filemanageracction
I:Loading page decrypt
I:Loading page trydecrypt
I:Loading page terminalfolder
I:Loading page terminalcommand
I:Loading page sideload
I:Loading page switch_os2sd_internal
I:Loading page installsu
I:Set page: 'clear_vars'
I:Set page: 'main2'
I:Switching packages (TWRP)
SELinux contexts loaded from /file_contexts
Full SELinux support is present.
mtd: successfully wrote block at 0
Set boot command "boot-recovery"
Startup Commands:
pm.sleep_mode=0
ro.bq.gpu_to_cpu_unsupported=1
ro.bt.bdaddr_path=/data/misc/bd_addr
ro.cm.device=thunderc
ro.cm.display.version=11.0-f2fs_os2sd_bigsuperROM
ro.cm.version=11-20140905-EXPERIMENTAL-f2fs_os2sd_bigsuperROM-thunderc
ro.cm.releasetype=EXPERIMENTAL
ro.sf.lcd_density=160
ro.com.google.gmsversion=2.3_r6
ro.com.google.clientidbase=android-sprint-us
ro.com.google.networklocation=1
ro.com.google.locationfeatures=1
ro.com.android.dateformat=MM-dd-yyyy
ro.com.android.dataroaming=false
ro.com.android.wifi-watchlist=GoogleGuest
ro.lge.proximity.delay=100
ro.max.fling_velocity=4000
ro.ril.def.agps.mode=2
ro.ril.def.agps.feature=1
ro.ril.def.preferred.network=4
ro.ril.disable.power.collapse=0
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.boot.emmc=0
ro.boot.selinux=permissive
ro.boot.hardware=thunderc
ro.cdma.home.operator.alpha=Virgin Mobile
ro.cdma.home.operator.numeric=311490
ro.cdma.voicemail.number=mine
ro.cdma.subscribe_on_nv_ready=true
ro.emmc=0
ro.twrp.boot=1
ro.twrp.version=2.8.0.0
ro.wifi.channels=
ro.allow.mock.location=0
ro.board.platform=msm7x27
ro.build.id=KTU84Q
ro.build.date=Fri Sep 5 12:51:56 CDT 2014
ro.build.date.utc=0
ro.build.host=build-mach
ro.build.tags=test-keys
ro.build.type=eng
ro.build.user=ack
ro.build.display.id=cm_thunderc-eng 4.4.4 KTU84Q f2fs_os2sd_bigsuperROM test-keys
ro.build.product=thunderc
ro.build.selinux=1
ro.build.version.sdk=19
ro.build.version.release=4.4.4
ro.build.version.codename=REL
ro.build.version.incremental=c72e706b78
ro.build.description=cm_thunderc-eng 4.4.4 KTU84Q f2fs_os2sd_bigsuperROM test-keys
ro.build.fingerprint=lge/cm_thunderc/thunderc:4.4.4/KTU84Q/f2fs_os2sd_bigsuperROM:eng/test-keys
ro.build.characteristics=phone
ro.media.dec.aud.wma.enabled=1
ro.media.dec.vid.wmv.enabled=1
ro.media.dec.jpeg.memcap=8000000
ro.media.enc.vid.m4v.bps=64000,1600000
ro.media.enc.vid.m4v.fps=1,30
ro.media.enc.vid.m4v.width=176,640
ro.media.enc.vid.m4v.height=144,480
ro.media.enc.vid.h263.bps=64000,1600000
ro.media.enc.vid.h263.fps=1,30
ro.media.enc.vid.h263.width=176,640
ro.media.enc.vid.h263.height=144,480
ro.media.enc.vid.codec=m4v,h263
ro.media.enc.file.format=3gp,mp4
ro.media.enc.jpeg.quality=100
ro.media.enc.hprof.vid.bps=8000000
ro.config.low_ram=true
ro.config.ringtone=Orion.ogg
ro.config.vc_call_vol_steps=15
ro.kernel.android.checkjni=1
ro.secure=0
ro.tether.denied=false
ro.carrier=unknown
ro.cmlegal.url=http://www.cyanogenmod.org/docs/privacy
ro.product.cpu.abi=armeabi
ro.product.cpu.abi2=armeabi-v6l
ro.product.name=lge_VM670
ro.product.board=thunderc
ro.product.brand=lge
ro.product.model=LG-VM670
ro.product.camera=msm7x27
ro.product.device=thunderc
ro.product.locale.region=US
ro.product.locale.language=en
ro.product.manufacturer=LGE
ro.baseband=unknown
ro.bootmode=unknown
ro.hardware=thunderc
ro.opengles.surface.rgb565=true
ro.opengles.version=131072
ro.revision=0
ro.serialno=
ro.telephony.ril.v3=signalstrength,skipdatareg,skipbrokendatacall,facilitylock,datacall,icccardstatus,1
ro.telephony.call_ring.delay=3000
ro.telephony.call_ring.multiple=false
ro.telephony.default_network=4
ro.bootloader=unknown
ro.debuggable=1
ro.modversion=11-20140905-EXPERIMENTAL-f2fs_os2sd_bigsuperROM-thunderc
ro.rommanager.developerid=cyanogenmod
ro.factorytest=0
ro.setupwizard.enable_bypass=1
ro.setupwizard.enterprise_mode=1
ro.HOME_APP_ADJ=1
com.qc.hardware=true
com.qc.hdmi_out=false
gsm.sim.operator.alpha=Virgin Mobile
gsm.sim.operator.numeric=311490
gsm.sim.operator.iso-country=us
gsm.operator.alpha=Virgin Mobile
gsm.operator.numeric=311490
gsm.operator.iso-country=us
net.bt.name=Android
net.tcp.buffersize.wifi=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.default=4096,87380,256960,4096, 16384,256960
net.change=net.bt.name
sys.checkfs.fat=false
hwui.print_config=choice
init.svc.adbd=running
init.svc.healthd=running
init.svc.ueventd=running
init.svc.recovery=running
rild.libargs=-d /dev/smd0
rild.libpath=/system/lib/libril-qc-1.so
twrp.crash_counter=0
wifi.ap.interface=wl0.1
wifi.supplicant_scan_interval=300
debug.gr.numframebuffers=3
debug.sf.hw=1
debug.egl.force_msaa=false
debug.hwui.render_dirty_regions=false
debug.qctwa.statusbar=1
debug.qctwa.preservebuf=1
debug.enabletr=false
debug.camcorder.disablemeta=1
debug.composition.type=mdp
media.stagefright.enable-aac=true
media.stagefright.enable-qcp=true
media.stagefright.enable-http=true
media.stagefright.enable-meta=false
media.stagefright.enable-scan=false
media.stagefright.enable-player=true
dalvik.vm.jmiopts=forcecopy
dalvik.vm.checkjni=false
dalvik.vm.heapsize=128m
dalvik.vm.heapmaxfree=2m
dalvik.vm.heapminfree=512k
dalvik.vm.dexopt-flags=v=a,o=v,m=y,u=y
dalvik.vm.heapstartsize=5m
dalvik.vm.execution-mode=int:jit
dalvik.vm.heapgrowthlimit=48m
dalvik.vm.verify-bytecode=false
dalvik.vm.dexopt-data-only=1
dalvik.vm.stack-trace-file=/data/anr/traces.txt
dalvik.vm.heaptargetutilization=0.25
persist.adb.notify=0
persist.sys.ui.hw=true
persist.sys.dun.override=0
persist.sys.usb.config=mtp,adb
persist.sys.dalvik.vm.lib=libdvm.so
persist.sys.dalvik.multithread=false
persist.sys.shutdown.mode=hibernate
persist.sys.strictmode.visual=false
persist.sys.root_access=1
persist.sys.recovery_update=false
persist.sys.purgeable_assets=1
persist.usb.serialno=0123456789ABCDEF
persist.rild.nitz_plmn=
persist.rild.nitz_long_ons_0=
persist.rild.nitz_long_ons_1=
persist.rild.nitz_long_ons_2=
persist.rild.nitz_long_ons_3=
persist.rild.nitz_short_ons_0=
persist.rild.nitz_short_ons_1=
persist.rild.nitz_short_ons_2=
persist.rild.nitz_short_ons_3=
persist.service.adb.enable=1
persist.webview.provider=classic
service.adb.root=1
keyguard.no_require_sim=true
movfilter=40
mobiledata.interfaces=rmnet0,rmnet1,rmnet2
windowsmgr.max_events_per_sec=150
DEVICE_PROVISIONED=1
I:Copying file /cache/recovery/log to /cache/recovery/last_log
Set boot command ""
I:Attempt to load settings from settings file...
I:Loading settings from '/sdcard/TWRP/.twrps'.
I:Copying file /etc/recovery.fstab to /cache/recovery/recovery.fstab
I:Version number saved to '/cache/recovery/.version'
__bionic_open_tzdata: couldn't find any tzdata when looking for CST6CDT!
I:Enabling MTP during startup
I:Starting MTP
twrp mtpid: 103
MTP Enabled
Starting MTP
created new mtpserver object
adding internal storage
MtpStorage id: 103 path: /sdcard
I:Starting command line thread
MtpServer::run fd: 17
I:Set page: 'advanced'
I:Set page: 'partsdcard'
I:Set page: 'action_page'
Partitioning SD Card...
umount: can't umount : No such file or directory
I:umount "$SWAPPATH" process ended with ERROR=1
umount: can't umount /data: Invalid argument
I:umount /data process ended with ERROR=1
umount: can't umount /system: Invalid argument
I:umount /system process ended with ERROR=1
I:sd card block device is '/dev/block/mmcblk0', sdcard size is: 7948MB, fat size: 6156MB, os2sd system size: 0MB, swap size: 768MB, os2sd data size 1024MB
Removing partition table...
I:Command is: 'parted -s /dev/block/mmcblk0 mklabel msdos'
I:parted -s /dev/block/mmcblk0 mklabel msdos process ended with RC=0
Creating FAT32 partition...
I:Command is: 'parted /dev/block/mmcblk0 mkpartfs primary fat32 0 6156MB'
Information: You may need to update /etc/fstab.
I:parted /dev/block/mmcblk0 mkpartfs primary fat32 0 6156MB process ended with RC=0
Creating System partition...
I:Command is: 'parted /dev/block/mmcblk0 mkpartfs primary ext2 6156MB 6924MB'
I:parted /dev/block/mmcblk0 mkpartfs primary ext2 6156MB 6924MB process ended with RC=0
Creating Data partition...
I:Command is: 'parted /dev/block/mmcblk0 mkpartfs primary ext2 6924MB 7948MB'
I:TWFunc::Set_Brightness: Setting brightness control to 5
I:TWFunc::Set_Brightness: Setting brightness control to 0
I:parted /dev/block/mmcblk0 mkpartfs primary ext2 6924MB 7948MB process ended with RC=0
mount: mounting /sdcard/.android_secure on /and-sec failed: No such file or directory
I:mount '/sdcard/.android_secure' '/and-sec' process ended with ERROR=255
Formatting OS2SD System as ext4I:Formatting OS2SD System after partitioning, command: 'mke2fs -t ext4 -m 0 /dev/block/mmcblk0p2'
mke2fs 1.41.14 (22-Dec-2010)
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
46944 inodes, 187500 blocks
0 blocks (0.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=192937984
6 block groups
32768 blocks per group, 32768 fragments per group
7824 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840
Writing inode tables: 0/61/62/63/64/65/6done
Creating journal (4096 blocks): done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 36 mounts or
180 days, whichever comes first. Use tune2fs -c or -i to override.
I:mke2fs -t ext4 -m 0 /dev/block/mmcblk0p2 process ended with RC=0
Formatting OS2SD Data as ext4I:Formatting OS2SD Data after partitioning, command: 'mke2fs -t ext4 -m 0 /dev/block/mmcblk0p4'
Could not stat /dev/block/mmcblk0p4 --- No such file or directory
The device apparently does not exist; did you specify it correctly?
I:mke2fs -t ext4 -m 0 /dev/block/mmcblk0p4 process ended with ERROR=1
Partitioning complete.
I:Set page: 'action_complete'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'mount'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'switch_os2sd_internal'
I:Copying file /etc/twrp_int.fstab to /cache/recovery/recovery.fstab
I:Copying file /etc/twrp_int.fstab to /etc/recovery.fstab
os2sd_switch: Internal.
=> Processing new recovery.fstab
I:Processing '/sd-ext'
I:Created '/sd-ext' folder.
I:Recreating and-sec folder.
I:mount '/sdcard/.android_secure' '/and-sec' process ended with RC=0
Partition Logs:
Display_Name: Boot
Storage_Name: boot
Backup_Path: /boot
Backup_Name: boot
Storage_Path: /boot
MTD_Name: boot
Display_Name: Cache
Storage_Name: Cache
Backup_Path: /cache
Backup_Name: cache
MTD_Name: cache
/data | /dev/block/mtdblock5 | Size: 158MB Used: 115MB Free: 42MB Backup Size: 115MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI IsPresent Can_Encrypt_Backup Use_Userdata_Encryption
Primary_Block_Device: /dev/block/mtdblock5
Display_Name: Data
Storage_Name: Data
Backup_Path: /data
Backup_Name: data
Storage_Path: /data
MTD_Name: userdata
Flags: IsPresent
Display_Name: misc
Storage_Name: misc
Backup_Path: /misc
Backup_Name: misc
Storage_Path: /misc
MTD_Name: misc
Flags: IsPresent
MTD_Name: recovery
/system | /dev/block/mtdblock6 | Size: 164MB Used: 74MB Free: 90MB Backup Size: 74MB
Primary_Block_Device: /dev/block/mtdblock6
Backup_Name: system
MTD_Name: system
/sd-ext | /dev/block/mmcblk0p2 | Size: 720MB Used: 16MB Free: 704MB Backup Size: 16MB
Flags: Can_Be_Mounted Can_Be_Wiped Can_Be_Backed_Up Wipe_During_Factory_Reset Wipe_Available_in_GUI Removable IsPresent Can_Encrypt_Backup Use_Userdata_Encryption
Display_Name: SD-ext
Storage_Name: SD-ext
Backup_Path: /sd-ext
Backup_Name: sd-ext
Backup_Display_Name: SD-ext
Storage_Path: /sd-ext
Fstab_File_System: ext4
/sdcard | /dev/block/mmcblk0p1 | Size: 5859MB Used: 0MB Free: 5859MB Backup Size: 0MB
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'mount'
I:Set page: 'selectstorage'
I:Set page: 'mount'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'mount'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'wipe'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'mount'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'wipe'
I:Set page: 'advancedwipe'
I:wipe list '/cache;/data;/system;'
I:wipe_path '/cache'
MTD Formatting "cache"
Done.
I:Recreating /cache/recovery folder.
I:wipe_path '/data'
MTD Formatting "userdata"
Done.
I:wipe_path '/system'
MTD Formatting "system"
Done.
I:checkpartitionlist list '/system;'
I:checkpartitionlist wipe_path '/system'
I:Set page: 'checkpartitionlist'
I:getpartitiondetails list '/system;'
I:getpartitiondetails wipe_path '/system'
I:Set page: 'partitionoptions'
I:Set page: 'selectfilesystem'
I:Set page: 'confirm_action'
Formatting system using make_ext4fs function.
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 5280
Inode size: 256
Journal blocks: 1024
Label:
Blocks: 42208
Block groups: 2
Reserved block group size: 15
Created filesystem with 11/10560 inodes and 1725/42208 blocks
warning: wipe_block_device: Discard failed
I:Set page: 'refreshfilesystem'
I:checkpartitionlist list '/data;'
I:checkpartitionlist wipe_path '/data'
I:getpartitiondetails list '/data;'
I:getpartitiondetails wipe_path '/data'
Formatting data using make_ext4fs function.
Block size: 4096
Inodes per group: 5072
Inode size: 256
Label:
Blocks: 40576
Block groups: 2
Created filesystem with 11/10144 inodes and 1699/40576 blocks
I:Set page: 'wipe'
I:Set page: 'main'
I:Set page: 'main2'
os2sd_switch: OS2SD.
Partition Logs:
Display_Name: Boot
Storage_Name: boot
Backup_Path: /boot
Backup_Name: boot
Storage_Path: /boot
MTD_Name: boot
Display_Name: Cache
Storage_Name: Cache
Backup_Path: /cache
Backup_Name: cache
MTD_Name: cache
/data | | Size: 158MB Used: 1MB Free: 157MB Backup Size: 1MB
Display_Name: Data
Storage_Name: Data
Backup_Path: /data
Backup_Name: data
Storage_Path: /data
Flags: IsPresent
Display_Name: misc
Storage_Name: misc
Backup_Path: /misc
Backup_Name: misc
Storage_Path: /misc
MTD_Name: misc
Flags: IsPresent
MTD_Name: recovery
/system | /dev/block/mmcblk0p2 | Size: 164MB Used: 1MB Free: 163MB Backup Size: 1MB
Backup_Name: system
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'mount'
I:Set page: 'usb_mount'
I:Device doesn't have multiple lun files, mount current storage
I:USB mount '/sdcard', '/dev/block/mmcblk0p1' > '/sys/class/android_usb/android0/f_mass_storage/lun/file'
I:Set page: 'usb_umount'
I:Set page: 'mount'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'install'
I:Set page: 'flash_confirm'
I:Set page: 'flash_zip'
minzip: Missed a central dir sig (at 0)
E:Unable to open zip file.
Error flashing zip '/sdcard/cm-11-20141025-EXPERIMENTAL-ext4_os2sd_bigsuperROM-thunderc.zip'
I:Set page: 'flash_done'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'wipe'
Done.
I:wipe_path '/data'
E:Unable to wipe '/data' -- unknown file system 'auto'
I:Set page: 'wipe'
I:checkpartitionlist list ''
Formatting Data using make_ext4fs function.
error: make_ext4fs: open: No such file or directory
Need size of filesystem
E:Unable to wipe '/data' using function call.
E:Error changing file system.
Formatting System using make_ext4fs function.
Block size: 4096
Inodes per group: 7824
Inode size: 256
Journal blocks: 2929
Label:
Blocks: 187500
Block groups: 6
Reserved block group size: 47
Created filesystem with 11/46944 inodes and 6074/187500 blocks
warning: wipe_block_device: Wipe via secure discard failed, used discard instead
I:Set page: 'wipe'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'settings'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'mount'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'main'
I:Set page: 'main2'
Partition Logs:
Display_Name: Boot
Storage_Name: boot
Backup_Path: /boot
Backup_Name: boot
Storage_Path: /boot
MTD_Name: boot
Display_Name: Cache
Storage_Name: Cache
Backup_Path: /cache
Backup_Name: cache
MTD_Name: cache
/data | /dev/block/mtdblock5 | Size: 158MB Used: 1MB Free: 157MB Backup Size: 1MB
Display_Name: Data
Storage_Name: Data
Backup_Path: /data
Backup_Name: data
Storage_Path: /data
MTD_Name: userdata
Flags: IsPresent
Display_Name: misc
Storage_Name: misc
Backup_Path: /misc
Backup_Name: misc
Storage_Path: /misc
MTD_Name: misc
Flags: IsPresent
MTD_Name: recovery
/system | /dev/block/mtdblock6 | Size: 164MB Used: 1MB Free: 163MB Backup Size: 1MB
Backup_Name: system
MTD_Name: system
/sd-ext | /dev/block/mmcblk0p2 | Size: 720MB Used: 12MB Free: 708MB Backup Size: 12MB
Backup_Name: sd-ext
/sdcard | /dev/block/mmcblk0p1 | Size: 5859MB Used: 232MB Free: 5627MB Backup Size: 0MB
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'wipe'
I:wipe list '/data;'
I:wipe_path '/data'
Done.
Block size: 4096
Inode size: 256
Label:
Blocks: 40576
Block groups: 2
I:Set page: 'wipe'
I:Set page: 'main'
I:Set page: 'main2'
Partition Logs:
Display_Name: Boot
Storage_Name: boot
Backup_Path: /boot
Backup_Name: boot
Storage_Path: /boot
MTD_Name: boot
Display_Name: Cache
Storage_Name: Cache
Backup_Path: /cache
Backup_Name: cache
MTD_Name: cache
Display_Name: Data
Storage_Name: Data
Backup_Path: /data
Backup_Name: data
Storage_Path: /data
Flags: IsPresent
Display_Name: misc
Storage_Name: misc
Backup_Path: /misc
Backup_Name: misc
Storage_Path: /misc
MTD_Name: misc
Flags: IsPresent
MTD_Name: recovery
/system | /dev/block/mmcblk0p2 | Size: 720MB Used: 12MB Free: 708MB Backup Size: 12MB
Backup_Name: system
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'mount'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'wipe'
I:Set page: 'wipe'
I:Set page: 'main'
I:Set page: 'main2'
I:Set page: 'main'
I:Set page: 'main2'
I:Copying file /tmp/recovery.log to /sdcard/recovery.log
the log says it didn't make the data partition at all, it put it at p3 instead.
try repartitioning but make sure to set the swap partition to at least 1Mb. looks like it was ignored.
Hey all. Been a loooong time since I was last on here. Life gets in the way sometimes. Been running the same internal build since like September: 4.4.2 with my Toucanscrypt and loving it! Problem is, I just got a bluetooth watch for Christmas and can't get bluetooth to turn on. Was this a glitch that was fixed in a later build, squid? If so, I may try to update to the newest. A few other questions...
1. How's wifi battery drain and clock lag?
2. Anyone having bluetooth issues currently or is it pairing just fine?
3. Any other recent glitches I should know about before upgrading?
Thanks all!
Hope everyone had a Merry Christmas, and wish everyone a Happy New Year!
that did it, it was weird though, swap wouldn't go to 1, it was either 0, or some higher number. I just ended up making a swap partition. It worked.
It's stable so far, deleted some of the system files like "cell broadcasts" and whatnot that I'll never use.
Only things I noticed, still having the speakerphone only ability. I know that the normal phone works, since it works on SlimBean. It's something that's remapping the phone to the speakerphone. Wierd, but liveable.
Also, I think I need to rerun the Sprint fix. The keys aren't right.
Last thing, I'll test the Pure Performance mod once I nandroid with all my apps and everything.
LOOVE IT! Got a lollipop theme installed. I'm giddy.
Thanks all!
still got wifi drain and clock lag.
I have no bluetooth issues: file transfer and keyboard both work fine.
um, last couple builds reported with possible video streaming issues though I haven't run into them myself.
10/25 'most' last stable right now.
the keyswap may not be in the fix :[
the speakerphone, probably something odd in the kernel.
I like the armv6 CrossBreeder version I put up, better than pureperformances; adblock works.
//edit: yep, keyswap missing.
should be one in the OPs somewhere I think. //edit edit: nope, lost for now. I'll dig it up later.
//edit edit edit: put it back in the OP for ya. Later maybe I'll add it to the Sprint fix proper, but for now this'll have to do.
suba
