[ROM+Kernel] Inferior Human Organs unofficial CM7.1
good advice. i have this happen to me quite a bit because i'm lazy and download the ROMs from on my phone instead of a PC. i reckon, what program do you use to check the MD5?
You can check it on the phone. Open terminal and type:
md5sum NAME_OF_FILE
Anyone with backside that concurrently updates it, you still use v6 supercharger? What option u played with on this build?
And i figured something snazzzy out. You can wifi tether to your ds's. I was playing around with my sons mario kart ds and could connect through my phone(just browser wifi, not wireless tether.)
I have tried 8-11 and 9-12 options in V6 suprecharger and it does not add anything to IHO. After testing for a long time, my experience is that Bob's v3.1 latest kernel handles everything better without it. I would recommend deleting it as I did.
Anyone have service crash in Central Florida? I make a call, lasts 4 seconds and then hangs up. Can't even call Virgin Mobile. Yes, my account is paid up. There is no indication of a service issue in my area according to the website.
sent from my Calkulin+Clemsyn 7 Gtablet with Clemsyn Kernal using Tapatalk
Thank god I'm not the only one having this problem... I thought it was the ROM. It is quite annoying, and I did all sorts of tests, but drew a blank and just gave up. Must be a service problem...
Edit: Forgot to mention I live in upstate NY. Whatever this is, its big...
Sent from my CM7'd NookColor using Tapatalk
Ok.... My wife's phone is on harmonia with the same issue. Definitely not the ROM. I still have text and data/web. No issues there.
Tbh its been sitting on my sdcard since everyone was hyped. Used it once. But stock rooted. Never toyched it since. Was jw
for some reason my phone wont vibrate anymore when i recieve text messages (it vibrates when i recieve calls and when im playing games on it)
Is it safe to rename the roms and flash them or will you break something?
Go to Settings > Notification settings > Vibrate in the messaging app and make sure it's set to Always.
~Azrael's Kiss~
There shouldn't be anything wrong with renaming the ROM's zip file, as long as you don't change the extension.
~Azrael's Kiss~
inglewoodpete
