[ROM+Kernel] Inferior Human Organs unofficial CM7.1
I'm on 0212 build of BACKside and still getting screen freeze. Is it still happening to anyone else? If not... Probably just a bad flash I guess
I just moved from the 1/31 build to the 2/12 and I immediately started having freezing issues. First time, I had half lock screen and "home" screen showing, which i managed to unlock. Second time, it froze locked on my home screen and I had to pull battery. I restored to the old build after.
I'm currently using 02/12, no screen freeze. I did suffer the issue in the first build of Feb.
Just fyi if it freezes up most of the time if you swipe over like your unlocking from your lock screen then rotate the phone it will unfreeze
Not just you, the fix didn't fix everything apparently. If there isn't a better fix ready by end of the week, I'll be removing the rotation animation.
Reactions: thewraith420
Jerry... have tried multiple times to download new build... tried updater... failed... tried direct from mediafire twice... failed... did manage to get it downloaded once, but then went to flash ans it aborted and said bad file... any suggestions?... I will try again when I get off work to download... mabey ill get lucky... thank you... :-)
If you checked the md5sum via the updater, then it's not a bad download. I have experienced where some recoveries will abort with a vague error (usually status 7 or 0), even though the package file is in fact fine.
I always do a second attempt at installing right after receiving such errors, and it has worked on the second try every time except one. ;)
Reactions: clodfelterac
jerry...ok... i tried a few more times... download unsuccessful... managed to get one through and checked md5... didnt match... heres a screenshot... and this was done via backside updater via opera... does that matter?.. hmmm.... i dont see why it should but i will try through tunny and see if that works after this post...
yes i love my green machine!!! thanks blarf, cyanogen, kermikalelite, jerryscript, bobzhome, and to any and all deevelopers that made and and continue to make this awesome mod happen and improve!!! and of course to the great ov community we have here!!! i read a good quote somewhere here; " lets work together to make something better than the parts." its not mine i take no credit... hats off to you all... :)
Reactions: JerryScript
I just downloaded a fresh copy from the github page with no trouble. I use dolphin hd browser. Just a thought tho... Perhaps your sd card is going bad? If you have another you could try to rule that out.
wraith... i have an 8g coming but sadly,it has not arrived yet... i am going to copy sd to my desktop, then do a triple wipe, then format everything, then flash rom/gapps, wait ten minutes, flash theme/activate bootsounds, wait ten minutes, redownload my apps fresh from market, one by one, remove bloatware, backup and reboot... then replace only pertinent files from desktop sd copy to freshly formated ovsd, change bootanimations and sounds, add ringtone, backup and reboot... then make new copies of all ov files to desktop...
jerry... tried backside updater via tunny... got the download but same screen when i checked md5s... alas my reply above... to be continued... :)
Well Mr Jerry. Since removing adw I haven't been getting freeze issues......until I enabled under " display"rotation. Once I did that I began freezing. I believe it's strictly a rotation issue from the
Stock display settings. Also I believe ill be sticking g with launcher pro. It responds nicer then adw. If there is a reason u can think of to not have anything but adw let me know lo
I now understand what the screen freeze is. I had it twice. One happened today while texting.
My phone keeps rebooting when plugged in. It doesn't do it always, but it seems whenever I plug my phone in and walk away I come back and find it rebooted. My work around is if I need the phone not to reboot randomly (like if I have an alarm set), I manually reboot as soon as I plug it in and it doesn't have any random reboots.
Reduce your OC. If that doesn't solve it, wipe everything and do a clean flash.
Are you trying to download via 3G or WiFi?
If via 3G, do you have a decent signal?
If via WiFi, do you have your wifi policy set to turn off when screen is off?
A couple of quick questions.
1) Has anyone gotten the built in sip application to work.
2) Has anyone gotten the built in USB tethering to work.
3) The right hand icons on the status bar are green no matter what. Is this because at one time I flashed the green machine theme? Is there any way to make them white?
MatthewD
