CuriousNoob
Banned
- Aug 2, 2011
- 1,590
- 202
- 0
^While were on this, does anyone know how to take apart the Optimus V?
Mine falls apart every time I drop it.
(sorry, couldn't help it)
I started to take the screws out, but then I'm afraid that I wouldn't know how to put it back together, I'm only 13. I'm good with Electronics and what not, just don't wanna break this. Had it for aloooong time.![]()
I'm currently running backside overclocked at 480 min 806 max using an interactive governor. Is this the best governor to be using? Looking to find a nice balance between performance and battery life. Thanks in advance!
I usually run at 122 (or whatever lowest is..) min. 600 max. Conservative governor. Battery lasts around 8 hours of kinda heavy use.. with no performance issues.
I have uploaded the new build 02172012 after syncing with the CM repo. There are two fixes for notification bar swipe and screen freeze during rotation. Tested on my OV and everything seems to be working fine. Enjoy!
- Synced with the CM repo and uploaded the new build 02172012.
- Fix display freeze happening when changing device orientation while screen is off
- Fix notification swipe handling
- Several other minor changes.
Thanks to Blarf, Bob, Jerry, LeslieAnn, tdm, thekraven, and the CM team.
ok where can i download this mirage build
