New build of BACKside is up:
Download via the BacksideUpdater
or
BACKside-IHO-VM670-03132012.zip
md5sum 9a5fa707bb2553e0bfb562b1e9ea6829
GreenMachineTheme-03132012.zip
Download DrewWalton's amazing touch screen recovery here!
md5sum bda76ec1214f88eeb922d05fb18fa1e7
Changes:
--Reverted fingerprint frameworks and pin landscape commits from CM - needs testing to see if this fixes reports of pin screen not functioning properly
--Added an experimental Suspend mode to the power menu - this will put your phone in a semi-deep sleep state similar to airplane mode - no phone calls or messages - but you will still get your alarms - might be good for overnite power savings when no charger is available
--Made the date in the status bar follow the clock color - been meaning to do this for a while now
--Made the status bar system icons follow the general theme of being green when active/connected
--Improved the functionality of the statusbar restart in settings
--Added ability to use any file manager with all BACKside tweaks - status bar mods - BacksideUpdater - etc - no more requirement to use OI File manager exclusively
edit-- forgot the bootanimation changer, it will be changed in the next build
--Added option in BacksideUpdater to download previous versions back to the beginning of the year - once a different date is selected you can download - view changelog - check md5sum - then reboot to recovery to install
--Added option in BacksideUpdater to install a recovery within the app - choose recovery file and it will install it - then reboot straight into the new recovery to test it - I highly recommend Drewwaltons touch recovery!
Note -- If the changelog doesn't show when you load an old version, swipe down in the black text box, it's because the last text showing was larger, will fix in next build.
Thanks as always to Blarf, BobZhome, mrg666, tdm, LeslieAnn, drewwalton, whyzor, bigsupersquid, kermikalelite, the CM team, the AOSP team, and a whole lot more!
Edit: Forgot, I fixed the png transparency support in the notification dropdown chooser.
