No way to remove it easily from the experimental build, but I will be posting a new build of BACKside with the wifi fixes and other non green machine stuff later today.![]()
Thanks.
Is there a normal wait circle? I feel that the ying yang makes the rest of it look tacky.
How large is the LatinIME.apk?
This is a dumb question but how do I install clockworkmod recovery? I got a .img file. How do I install it? Or can I just flash the latest from rom manager?
Your newest build seems like there's a lot of personal tweaks..
Ok mrg666, I reinstalled your latest version and still having the USB issue where it won't show the mount option in the bar. I have tried uncheck recheck debugging.
I am using asop clockworkmod listed in wiki
Formated everything
Recovered BumbleBee and it works perfect
Installed BobZ version and same issue, so maybe something was changed in IHO. I have not restored any apps as of yet.
so is it safe to uninstall the latinME.apk?
I plan on fully incorporating the bootsound feature into the ROM, menus, multiple selections for sound files and formats, and of course an easy disable checkbox.
For now, it can be disabled by removing the android_audio.mp3 file located in /system/media
Hi, the build is not my version. It is pure IHO; I have only built it. So, your feedback is counted as a bug report for IHO. Running the same build, my OV is able to connect to 3 different computers thorugh USB without any problem, two of them windows 7 (laptop + desktop), the other is Windows XP laptop. I suspect your computer has a problem not IHO.
