Code:Installing: SDCARD:download/Cyanbread-signed.zip Finding update package... Opening update package... Verifying update package... Installing update... Installing Cyanabread mount() expects 4 args, got 3 E:Error in /sdcard/download/Cyanbread-signed.zip (Status 7) Installation aborted.
Cyanabread is not a typo, that's what it says.
Update on my battery situation... Left GPS on all day today and barely a drop in battery life. Working great now.
Sent from my LG OP V using Tapatalk
The GPS bug is only noticeable as a difference in drain before & after GPS use. You'd have to have the same conditions before & after, like idle for 1 hour before toggling GPS on & off, then idle for another hour after, and see the battery usage graph. Otherwise one persons' "barely a drop" could be someone else's "wow that drained fast". I get less than 1%/hr idle before GPS use and am ok with that, but 2-3%/hr idle to me is already too much.
Can someone upload the cmwallpapers.apk for me? Im on mrg666's build which doesnt have it. I cant download and extract it from other builds since i dont have internet access on any computers and my 3g is super slow. Thanks
Any build after August 16th will have the broken GPS, unless you revert the changes. The changes that Blarf posted two days ago to his git broke the GPS. He was trying to fix the battery drain that the GPS causes. My ROM was built on the 14th, so it has a working GPS.Are you guys sure the GPS isn't working?
I'm on the latest BobZ build and it takes minutes, not seconds, to start picking up a signal, but it does work.
Followed build-to-build upgrade instructions (wipe cache, wipe dalvik, flash) to rollback from 0817 to 0810. Now Status Bar (com.android.systemui) force closes.
Any thoughts on rectifying it with least amount of effort ?![]()
Has anyone filed a bug report for the GPS?
I haven't updated my rom and a bug report should be someone who experienced it first hand.
