[ROM+Kernel] Inferior Human Organs unofficial CM7.1
I am also, now, missing the boot animation with the latest build of BACKside. I always do a complete wipe when flashing a new rom. Tried twice and it seems to be the only problem. Not that I care much since I only reboot once in awhile. Was just reporting. :)
Its not there on purpose i think he wanted us to freak out when it says phone will self destruct in 5 seconds and then all it shows is a black screen. Kinda funny if you think about it.
That would be funny if it came up with a countdown 5, 4, 3, 2, 1, your phone will now self destruct.
I replaced the bootanimation.zip with my own and it works properly again.
Is anyone else having a problem when on wifi were it says you have no connection. It only happens like like twice a day, and turning it off and on again fixes it. Just checking if i'm the only one
I actually have a gif that is a countdown from 5. Jerry should have said something to me lol.
Jerrys last build is great. Everything works great keep up the good work blarf,jerry,and all the rest of u awsome rom cookers.i freaking love IHO roms.
when i listen to music on my phone sometimes theres a lil crack about 4 times in one song ... i know its not the songs file because i used to listen to it
I like the flashlight feature on the power control widget. Just discovered it today while playing around with the phone. It will come in handy at night. I don't have to have a seprate flashlight app installed now.
I noticed this too. However it is not with every song and not that many times. It seems random. May happen once or twice in a song.
yeah it is at random. but like when it does happen then it does it for 4 times in a song :( i hope they fix it.
August 26 build of IHO-Purity is up.
Changelog:
-Sync'd with CM
-Email.apk updated on the CM side, need feedback if it is fixed now. I have not replaced it with an earlier build this time.
-Known issue: longitude set incorrectly by camera.apk
Download MD5: 13cc3da11b563323e1f712603ec3e688
Jerry, quick question. You said there were issues with recent builds. I'm currently running, 0820 (settings>about phone), serious problem when screen shuts off, battery dies in 45 minutes. I downloaded and installed this on 8/24 as the 8/24 update. Can I just revert to last known good and wait until I get home to install your latest and greatest?
sent from my FlashBack 7.2 Gtablet using Tapatalk
I followed every step given to flash this from my stock rom and everything went smooth and installed correctly but when I rebooted my phone I could hear the startup sound and feel the vibration when the home menu is about to start but there is no image at all, just a blank illuminated screen. Any ideas on what I might be doing wrong?
If you have a newer or refurb phone you may want to look at this. http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/113762-fix-black-screen-custom-recovery-custom-roms.html
Reactions: JerryScript
asnes
