[ROM+Kernel] Inferior Human Organs unofficial CM7.1
Okay, I'm sick of this issue with google voice.
Isn't anyone else having an issue where any incoming calls through google voice getting sent directly to voicemail without ringing at all first?
Sent from my Optimus V using Tapatalk
I have the problem with google voice and grooveip, it does ring for me but only once or twice.It only happens some of the time though. I do have another question though do wired head sets not work with the IHO roms?
Jerry, quick question. You said there were issues with recent builds. I'm currently running, 0820 (settings>about phone), serious problem when screen shuts off, battery dies in 45 minutes. I downloaded and installed this on 8/24 as the 8/24 update. Can I just revert to last known good and wait until I get home to install your latest and greatest?
sent from my FlashBack 7.2 Gtablet using Tapatalk
Have you tried the 0825 build? Getting great feedback on it, hopefully it will fix your issue.
Reactions: sharpe351
Ive never used google voice or groove ip.
Groove ip seems great, but all the recent feedback for google voice looks like shat. Can anyone who uses it chime in? Easy to use? By the looks of the feedback alot of people are saying it is getting in the way....
Sent from my IHO Powered LG-VM670
Headset Problems
Best Rom but having a prob with headset Mic doesn't work or the buttons. Great work Guys I.H.O is GREAT!!. Running Jerry's latest build . Has this been talked about if so can some1 link me to the discussion
Thanks Jerry for the quick response. I will install it as soon as I get back to my home computer. I went ahead and reverted to the "last known good" (force of habit) build and the phone is working much better.
Introducing the BACKside ROM, a port of CyanogenMod7 for the Optimus V.
Edit: Updated 08252011, download links at bottom of post
Credits:
Blarfie - For creating the IHO repository, and fixing most of the bugs with CM7 OV ports
AOSP - The Android Open Source Project for creating the offical Android source
CyanogenMod - The entire team for all their hard work creating the best Android Mod available
KermikalElite - For helping me set up my build environment and compiling this ROM
Special thanks to ath3nos - for getting the ball rolling on the S, zefie - for his original work on CM7 port for the OS, mik_os - because he started it all, and many others who I may have left out! Thanks to Danny Baumann for fixing the custom ringtones!
STANDARD WARNING-- Flashing any custom ROM may semi-brick your phone!
Follow the installation instructions to the letter!
Always backup your apps, and do a backup in recovery before flashing!
This is a WIP (work in progress)!
This is the Optimus V build of the inferiorhumanorgans repository which is forked off the CyanogneMod7 source tree, the same as ath3nos, but built for the Optimus V and not the Optimus S. No S-to-V script necessary. There is also an optional Green Machine theme built in UOT Kitchen for those who are interested, or you can theme your own if you like.
KermikalElite was the first to build for the Optimus V from the IHO source, and you can find his latest buiilds, and other users builds, in Blarf's OP.
Installation
---Updating from a previous BACKside-IHO build
1) Download the newest build, and GreenMachineTheme zip if you like, and place them on your sdcard
2) Boot into recovery and make a backup (imho, not optional ;))
3) Wipe cache and dalvik cache
4) Flash the BACKside-IHO zip file
5) Flash the GreenMachineTheme (optional)
6) Reboot and enjoy
---Installing from another ROM
1) Backup your apps with something like TitaniumBackup or MyBackup
2) Download the BACKside ROM zip file, the gapps zip file, and optional GreenMachineTheme zip file linked below and place them on your sdcard
3) Boot into recovery
4) Make a backup (ALWAYS RECOMMENDED!)
5) Wipe cache, and under advanced wipe dalvik cache
6) Under mounts, format boot, system, data, and cache (only recommended when coming from a different ROM)
7) Flash the BACKside ROM zip file
8) Flash the gapps zip file
9) [Optional] Flash the GreenMachine-UOT zip file for the Green Machine Theme
10) Reboot your phone
11) Restore apps, but DO NOT RESTORE SYSTEM APPS!!!
12) Enjoy yummy gingerbread and the CyanogenMod goodies
Getting More Space
Barebones - CyanogenMod Wiki
Known Bugs
USB Mass Storage is not working, you will have to use ADB or put your sdcard in another device for file transfers
(Blarfie is working on it, Windows USB drivers can be a nightmare)
Fixed 07212011
Custom ringtone settings are not followed, default ringtone rings instead Fixed 07302011
Camera sometimes places artifacts on the edge of images when zoomed at some levels.
(The problem is known, expect a fix, but other things have a higher priority right now)
Fixed 07302011
Voice Dialer button is not mapped, use Button Remapper from the market and set it as you like.
GrooveIP disconnects and deregisters when attempting to place a call through it's interface.
Android Market web interface doesn't allow automatic installs, says country is not supported. Fixed, see this post
Screenshot app from the power button menu saves the images inverted 180 degrees, you can fix them with any photo editing app/prog, I just let photobucket take care of these screenshots. Fixed 07212011
Screenshots with Green Machine Theme installed over the build
In order to keep this as close to CyanogenMod7 source, I have left all the extras in there, which makes for a large install. You can use a bloat removing script such as mmarz's, or manually delete ringtones, wallpapers, etc as you like. If there is enough interest, I will post a slimed down version with most of the bloat removed.
Downloads
Download Blarf's new recovery here
Download aospCWMod version of ClockworkMod here
Download updated 08252011 ROM here
md5 checksum 207fce1da7237ae298a4905b6dff04a6
Download gapps here
Download the Green Machine Theme 08102011 flashable zip file from here
Changes
Note, this is not an all inclusive list of changes, please visit Blarf's repository for all the changes/commits/requests.
Changes 08252011: Synced with Blarf's repo, most bugs from 0824 and prior builds are fixed
Changes 08242011: Reverted to previous build to fix 0823 bugs, once we sort out the repository's commits I'll post a fresh build.
Changes 08232011: Synced with Blarf's repo, IHO merged with CM7.1 lot's of little fixes, new bootanimation incorporates IHO logo (needs work to smooth out the transition), bootsounds working properly now, see wiki for diff from pure IHO
Changes 08202011: Synced with Blarf's repo, GPS now properly enabled, lots of small cleanup items, small audio tweaks
Changes 08172011: Synced with Blarf's repo, GPS changed to hopefully improve battery performance (needs testing), second partition on sdcard should mount, minor background changes to libaudio, lockscreen, and profiles, changed second boot logo to IHO
Changes 08102011: Synced with Blarf's repo, Sound always playing through the speaker regardless of settings has been fixed, BobZ's wifi fix included and another small tweak (if this build fixes issues, wifi bug should be fixable), Updated to Blarf's newest kernel r1.2, tweaks for battery and performance, Camera exposure mostly fixed though default value may still be too dark, Removed bootsound for now due to overwhelming requests (but you can enable it using eollie's script). Some bloat removed.
Changes 08082011: Edit: Now there is a themeless build with the experimental tweaks mentioned below built in for you tasteless types :p
Created experimental Green Machine ROM, this one will have the green machine theme built in. It has a couple of wifi tweaks we hope will help those with wifi issues, bootsound support (thanks eollie), camera exposure (still buggy, but better), no more reset of death under privacy settings, added video icon to app drawer (thanks asadullah), smaller LatinIME.apk (thanks to mmarz's script), and most of the bloat removed (wallpapers, large ringtones, themes, extra tts languages). To change the bootsound at startup, replace the android_audio.mp3 file in /system/media, or just delete it for no bootsound.
Changes 08032011: Synced with Blarf's repo, GPS should now lock on faster (needs testers), dBm reading in status bar fixed, Market apps that should work on OV not installing should be fixed now, some changes to SIP services should make native SIP work better, boot time should be faster
Changes 07302011: Synced with Blarf's repo, Camera zoom and autofocus improved, custom ringtones now work, BT functionality improved (needs testers)
Changes 07272011: Synced with Blarf's repo, Mostly build.prop changes to allow Android Market web interface installs, some other fine tuning.
Changes 07252011: Synced with Blarf's repo, new kernel r1 should fix the charging issues some were having
Changes 07222011: Synced with Blarf's repo, new kernel v53 with USB tethering support working in OSX, may be a bit buggy on Windows, ext3 support added, now have ext2/3/4 built into the kernel, couple of other small commits, changed carrier name to Green Machine in the theme only.
Changes 07212011: Synced with Blarf's repo, new kernel v49 with built in ext2/4 support, fixed screenshot from power button being flipped, USB mass storage now working, circle-particle bootanimation included again, some behind the scene changes
Changes 07202011: Updated repo to include Blarf's new kernel v41 (with ext2 support, see his posts on page 2), and his stock binary blobs, screen rotation fixed, forgot to add in the circle-particle-cyanogenmod bootanimation, you can download it from here and push it to system/media if you like it.
Awesome work! However my MMS would not work. Any ideas?
I use google voice all the time.
no app, though. I use it "raw" and have it set to ring my optimus with accurate caller id.
every now and then it doesn't ring through but it usually works fine and no ROM I've tried changes its functionality.
Am I the only one having problems with a link to Blarf's new recovery download?
All links can be found on the wiki, the recovery has it's own page:
https://github.com/inferiorhumanorgans/android_device_lge_thunderc/wiki/IHO-Recovery
MMS definitely works. Be sure you have 3G enabled, sms works without 3G but mms needs it. If you can't get it to work, you will need to backup all your apps with TitaniumBackup or MyBackup, then go into recovery, wipe cache/dalvik_cache, then format boot, system, data, and cache. Then reflash the rom, reflash gapps, then reboot and reinstall your apps, BUT DO NOT RESTORE SYSTEM APPS OR DATA!!!
ANYONE WHO STILL HAD WIFI TROUBLE!!!! This might also help.
I live in an apartment complex and there are A LOT of wireless networks cluttering my airspace.
I figured that my wifi issues were at first IHO related. Maybe some were but but I had trouble with an important Skype call one night while using BumbleBee and still had trouble.
I figured that I needed to change my wireless channel. The link below helped me decide what channel to use.
Change Your Wi-Fi Router Channel to Optimize Your Wireless Signal - How-To Geek
Turns out everyone with in range was using channels 1, 6, or 11.
I now use channel 9.
Reactions: Eollie
I think wifi ,may be a bit hinky on the aug27 builds.
Takes forever to get an IP address.
It's not your channel, it just finally got an IP. The first time after install took almost 5 minutes compared to the 10 seconds it used to take. And no, my channel is clean. Subsequent connects have taken about 30 seconds.
on the 24th and 25th build of backside. I couldn't sign into my account to sync with it. I know I'm putting my info correctly but it's saying it cant connect to the server. Comes up with
user name
password and
server
I have to input into.
Estherlampard
