[ROM+Kernel] Inferior Human Organs unofficial CM7.1
For those that are having issues with market not showing up after flashing Gapps, can you do a quick test?
Please post results as:
1) Custom Gapps - "works" or "does not work"
2) Gapps - "works" or "does not work"
3) Newest Gapps - "works" or "does not work"
Then any comments...
Thanks for testing,
Bob
Custom Gapps - Works
Gapps - Works
Newest Gapps - works
Steps I took to get Gapps working:
1) Reboot into recovery
2) Wipe cache / delvik
3) Flash ROM
4) Reboot
5) Reboot into recovery
6) Flash Newest Gapps: http://goo-inside.me/gapps/gapps-gb-20110828-signed.zip
7) Reboot
Not sure why I had to do it that way, but it worked.
Reactions: BobZhome
Ya, I always boot after flashing ROM. I change all my setting to my liking, then boot into recovery again to flash Gapps. It may be why I don't have that problem...hopefully this will help the others
Thanks for testing,
Bob
Test 1:
1) Backup your current ROM
2) Wipe/format everything EXCEPT SDcard
3) Flash ROM
4) Flash my custom Gapps: gapps-gb-20110613-BobZ.zip
5) Reboot
See if market shows up...
Test 2:
3) Flash ROM
4) Flash Gapps: http://goo-inside.me/gapps/gapps-gb-20110613-signed.zip
5) Reboot
Test 3:
3) Flash ROM
4) Flash Newest Gapps: http://goo-inside.me/gapps/gapps-gb-20110828-signed.zip
5) Reboot
Thanks for testing,
Bob
In my tests of all three gapps,zip flashing them after installing the ROM moves all of the apks into the /system/apps folder, but does not install them.
The question/test was not answered...was market installed correctly with any of the Gapps?
Did you try Spiral_ouT fix:
Code:
3) Flash ROM
4) Reboot
7) Reboot
to see if it worked for you?
I flash the rom and the new gapps 8/28 and then rebooted and it worked fine.
I just want to say that Bob zhome's. V3.1 kernel is amazing! Thank you.
Sent from my LG-LS670 using Tapatalk
I have updated my build in the Wiki with 09242011. Synced two recent merges in the CM framework/base repo adding missing functions in the 2D accelerated rendering libraries. I wanted to test if OV had any benefit from these merges. So, if you try please post here if you see any improvement on the screen animations and transitions. I am not sure if this is placebo effect but there seems to be some improvement on the screen animations on my OV. There are no other changes.
Reactions: digitaljeannie
See, I knew as soon as I took the plunge and converted to IHO & got everything set up the way I wanted you'd post a new update. hahaha.
I have my windows animations turned off so I probably wouldn't notice a change so I'm gonna stick with the 9/22 build for now. But i do want you to know that after putting your 9/22 build on my phone, my battery life on idle overnight was about 2% per hour which is really quite decent and the battery drain overall seemed fairly on-par with what I've gotten on other ROMs. I did just recently recalibrate my battery so may have something to do with it, not sure, but I didn't notice an increased battery draw that others had expressed.
I had so much fun being home with my germs yesterday and just geeking out on my phone all day long that when the DH got home, I talked him into letting me geek out on his phone too and he absolutely loves his new purple themed phone and I assured him that I restored his apps properly so he wouldn't have to start Angry Birds all over again.
Reactions: mrg666
The new gapps worked for me as well. Wiped, flashed ROM, Gapps, Launcher & email, in succession, then wiped again & rebooted. all seemed well
Sorry, I can't stop myself from building another when I see a change in the repo ... yet :)
2% per hour is also about the same I see on my phone. Get well soon.
I'm liking IHO so far. The battery life is so much better than my samsung intercept and I finally have access to CM7! It took me about 30-40 minutes to get it stock to IHO up and running. The V is my 3rd android device so the time it takes to ROM'd up a device gets shorter and shorter each buy.
Since I have the the 2.2.2 V, can I use ANY IHO rom? I flashed the EMU-zombie one to avoid the black screen I have been reading about. I had to use android screencast to get rid of the one I installed from ROM manager..
Is there a dedicated page/thread that lays out the details of MiRaGe that's updated with new builds? (Similarly to how post #3 of this thread lays out the details about BACKside along with install notes and all needed file links).
Sent via VM670
Is there a page/thread that lays out the details of MiRaGe? (Similarly to how post #3 of this thread lays out the details about BACKside along with install notes and all needed file links).
Sent via VM670
Well, I was asked to find a designation for my builds and I chose that name. MiRaGe is IHO. I don't add anything but just remove the clutter. So, there is no other information needed than it is available in the Wiki. All of those information is generic, instructions apply exactly to my build, and I add there as needed. There are no additional files needed other than gapps which is there again. But I have put there some optional files (a light theme and stock Android Launcher), see "Optional Files" section in the same page. You can also find there what was removed; all of the builds are briefly described on a table.
I started building just to have an unmodified and lean IHO for myself and I am sharing with the community as a way to contribute. So, I don't think there is any more information needed but please ask here if you want to know anything else. Please thank Blarf, Bob, and Jerry. I just build and help around a little bit to do that.
You can choose any build over there after September 1st as written in the Warning statement just after the list of binaries. Yes, the battery life is very good. My OV with IHO can easily survive past 24 hours when needed.
Is it recommended that you flash gapps after you flash the ROM like you do with BACKside? And if so is there a particular one to use, or just use the same one from that BACKside post?
Sent via VM670
I just flashed this ROM, coming from the latest BACKside, gonna see how it goes, looks good right now
dhickman
