[ROM+Kernel] MiRaGe-CM7.2-IHO (07132013)
Re: [ROM+Kernel] MiRaGe-CM7.2-IHO (03122013)
Something else to try.
Open terminal Emulator and type in:
Code:
su
fix_permissions
Well, i did the fix _permissions this morning, phone ran fast and smooth all day, no reboots until i unplugged my charger, then the phone reboots.
So i guess it's the charging port that's bad, i think,..
I'I'll continue running like this for awhile see how it goes, then maybe do a clean install. I don't know, if it is the port that's loose, I i'll just have to live with it for now.
Is it still under warranty?
If so call virgin and tell them. They send you a free replacement. Just flash zv9 update so its 100% stock.
I love this show.
Sorry to hear that. Try downgrading to the Resurrected Bumblebee and see if you have any reboots. No need to overclock as it's already set at 480MHz-768MHz. If it still auto reboots in same situation, its the phone that's bad.
I love this show.
I wish it was but unfortunately it's almost 2 years old. :'(
Thanks Andy, i'll try it see what happens.
That's a bummer, these phones are tanks for the most part, but that stuff happens. You could always grab a used one on ebay for about $30, and occasionally new ones come up for at $50.
I forgot one other thing.
Sometimes a corrupt piece of data on the sd card can cause reboots as well. Get a flash drive, go to a library (most have computers for use) and transfer data from card to flash drive. Then erase the sd card with the option in setting/storage. Reboot phone.
If you no longer get reboots it was a corrupt piece of data on the sd card.
Just re-install your clockworkmod folder, MUSIC, DCIM, Titanium Backup, Etc., and whatever folder has your apps that you moved to the sd card.
Hi everyone. It's been a long while since I've been lurking in the OV forums. I got the S2 about a year ago.
I have to ask because he was such a helpful individual on this forum. What happened to Jerry Script? Did he move on to another phone or completely vanish?
Sent from my SPH-D710 using Tapatalk 2
He vanished from the android scene. Seems he took up sterling engines.
Sent from my PG86100 using Android Central Forums
For the past 5 days my phone has been very laggy. What should I do? Should I wipe everything including my apps and reinstall the rom? The phone app is specifically the worst, crazy laggy when I dial/call.
That would probably help. You can use titanium backup to backup and restore your apps, or any of the other backup apps.
First, open link2sd settings > more. Do clean cache, clean dalvik-cache and reboot. Might help
There is a kernel update in the OP. You can find the changes in my repo.
Any chance you will make a kernel for the Galaxy Nexus(Verizon).
Going to be totally honest here, I REALLY miss your kernel lol.
There's a name I haven't seen in a while! Still keeping an eye back here from your Nexus I see.
Tapatalk'n it PAC-Rom style! Android 4.2.2 on my VM670 running LS670ZVJ firmware
Without a doubt, I ALWAYS keep an eye on this phone lol. I know use it as a wifi hotspot :p
I wish I could but I don't have the device. Thanks for the comment.
Does the latest kernel support usb fast charge?
Yes.
Went here: https://github.com/mrg666/android_kernel_thunderc/downloads.
Got this:
There aren't any uploads for this repository.
I can't add new builds there since github does not support uploading binaries anymore. The remaining binaries were very old and I have deleted them. I have the kernel build links in the OP now.
mrtalha
