[ROM] Official CM10 Nightlies on your GS3!
Yea that would do it too. For some reason with CM10, whenever you reboot your device or on first boot you need to changed the radios to LTE/CDMA/EvDo. I had to do the same thing as well. Have no idea why that makes a difference but that has been a bug since early builds.
Do you have any idea why I get random call quality issues where the speaker is so loud it distorts to the point where its hard to hear?....I know they had issues with the speaker being loud but I thought with M1 they took care of it.
Sent from my SCH-I535 using Android Central Forums
That's still an ongoing issue last I heard. Its even s slight issues with AOKP. I got a lot of static feedback on a couple CM nightlies but since I dont talk on the phone all that often didn't affect me.
Sent from my Nexus 7 using Xparent SkyBlue Tapatalk 2
Is anyone having issues with the proximity sensor while in calls? I'm on OFFICIAL nightly 10-1. When I made a few calls today with the dial pad on the screen, my cheek kept pressing the 1 key and sometimes a few others. This was happening consistently in many calls for me. I even tried holding the phone differently and it kept pressing keys when my cheek would touch the screen.
Installed CleanRom 2 last night... sorry if this is the wrong thread...
My 4g speeds went from 18-22mbps to 5. Any ideas?? Using Speedtest with multiple servers and it all show poor numbers. Thank you in advance and sorry is it's the wrong thread (you all just seem smart).
I haven't noticed that with CM10, however I can say that the proximity sensor was a little "testy" at times when I did use it. When I was using and made phone calls I had no issues what so ever but I did notice that it wasn't working 100%.
Sigh... nothing a battery pull for two minutes couldn't fix.
No problems, honestly it could be anything. I wouldn't say the ROM was causing the issue, but it is possible the time when you where testing it. I don't put much stock in those speed tests but I can see your concern. My first step in trying to correct network issues is to toggle airplane mode. If that doesn't work then the standard reboot/battery pull usually does the trick. Have you flashed the newest radios? What is your baseband version under phone info settings?
After using my phone again later that night the proximity sensor didn't give me any further issues. Don't know why it was giving me problems on several back to back calls.
Getting constant wakelocks from "Direct Track" on the latest CM10 nightly. Tons of other people are complaining about it and they are supposedly working on a fix. Also i cannot get the CM10 OTA updater to work.
---------- Post Merged at 01:26 PM ---------- Previous Post was at 01:25 PM ----------
You guys are a hardy lot testing these nightlies. Thanks, I guess someone has to do it :)
It's really kinda fun. If something is broke you can just revert to a backup and all is well.
Sent from my SCH-I535 using Tapatalk 2
It is very addicting but for some reason a little part of me dies inside every time I do it. That scared first time root and ROM experience comes back to me!
It is addicting... but sometimes I wonder if its worth it. VERY RARELY is there ever a nightly that clears up an issue that I'm having. That being said, I barely have any issues with any nightly I'm on. Basically, the ROM already feels nearly perfect. Flashing nightlies every day doesn't do so much for me, because they rarely fix or add anything that I'm affected by.
Running 10/08 build. Having issues with screen rotation back to portrait from landscape. Didn't have this problem in 10/06 build. I was going to post this on Xda site in the proper thread but it won't let me because I don't have 10 posts or greater.
Found out it is a result of dirty flashing. Went into recovery and did full wipes and reinstalled new nightly and running smoothly again. Don't recommend dirty flashing anymore.
Question about the profiles in CM10. Can this be used to launch an app when the profile is selected. For instance i want to select my "car dock" profile and have it launch Car Home Ultra automatically. Anybody have any idea how to do that? My car mount does not put the phone into car mode when its mounted.
I'm not sure about that but I have seen people use NFC tags with tasker. They put an NFC tag in their car that launches car dock when you drag over it.
wilderjohn7
