Figured it out...was scared for a bit!Guys I need help my rom didnt flash correctly and it wont boot. What do I do?
What happened?
Sent from my SCH-I535 using Tapatalk 2
Basically I flashed aokp build 5 and it would only boot to the Samsung screen...then black. I think the reason it happened is because I flashed like 5 things at once. ROM, gapps, kernel, baseband etc.
Sent from my SCH-I535 using Android Central Forums
How is build 5? You like it?
Everything about aokp is amazing except 2 things that I'm trying to get over. Lock screen vibration is always on, and you can't set the capacitive keys to what you want unless you choose to have on screen buttons :thumbdown:
I might have to check it out one of these days...
What are you running cm10 was starting to p*** me off so I decided I'd try this
Was thinking about also trying (codenamedriod), it's cm10 and aokp combined. There is a stable version for our device.
I was on m2 and it kept wanting to reboot over and over until I would do a manual reboot or battery pull. I tried clean flashing it a few times. Haven't tried CNA yet but they tend to be more buggy when throwing all that extra stuff in the fold. I had tons of bugs on Baked ROM even though it was sick looking
Oh I didn't know that about cna.. I can't think of why you where having them problems with Cm10. I guess that's why they say every phone could act a little different than others.
You can always give it a shot. I mean it doesn't take long to go back if you aren't satisfied. I get bored and do it all the time. I have just found that when they are adding all those custom features there tends to be more things that can go wrong. Creccaj got me thinking this mentality and now he's getting me into aokp the more he posts about it Haha.
Lol, yeah I have been reading his posts about it. Makes me want to try it to. I just can't get past that unicorn thing though. I hate unicorns.
You can disable the boot animation or put a custom one on your SD card with aokp
