[ROM] Official CM10 Nightlies on your GS3!
Solid enough for a daily driver? I'm looking for the best daily driver ROM.
I doubt it ... I'm running the 2.00 paranoid android and I'm using it for about 2 days and everything is really great other than battery but I'm still experimenting with kernels and what not
sent from my paranoid JB GS3
I would agree. If you need an extremely solid ROM that you can expect minimal bugs than you might want to flash an ICS/TW based ROM. Jelly Bean ROMs right now are still experimental and in beta/alpha phases.
Went back to using CleanROM for a bit. Like the stock look of TW without having all the bloat.
OP updated to reflect newest 8/31 nightly.
Still running 8-16 nightly and so far its solid....a little lag now and then on the home screen...anyone flash the new nightly and if so is it worth moving up to?
I flashed 8/29 the other day and I didn't have any lag. Just wanted to go back to a TW rom since I actually like some of the features that are here.
Sent from my SCH-I535 using Xparent SkyBlue Tapatalk 2
Were there any call issues on 8/29 ?
Sent from my SCH-I535 using Android Central Forums
CM posted a second 8/31 nightly. I am sure that tomorrow they will be bouncing out another one as well lol.
I flashed the 08/31 Nightly and everything seemed to work fine except for a couple of things that I noticed: 1. The screen flicker (not a big deal at all really and apparently their is already a workaround for it) and 2. The earpiece volume is way too loud no matter what I do.
I flashed 09/01 nightly and I still have to same volume issues that are a deal breaker for me. I love the rom otherwise and if anyone has a fix for the loudness issue I would love to stick with it.
I found the same issue with the loudness as well. I noticed it when you play a ringtone on full volume it sounds distorted because it is so loud.
The screen flicker has a fix which I posted in the OP. Have to enable HW Overlay in Dev Options.
Does Any one have a GPS issue? My gps will lock on but after a couple minutes it will lose the lock.
Can't say I have experienced this but I do not use my phone for GPS often. I used the GPS on an early build and didn't have an issue. I noticed that in the newest build (9/01) that GPS would acquire very quick though which is a good start.
Man I want to flash something new but all these issues you guys are having with the new nightlies makes me want to stay on 8-16...I'm not experiencing anything bad besides Apollo crashing time to time
Stick with it then lol. I am waiting for a RC to come out before I go back to it.
Brabian
