[ROM] Official CM10 Nightlies on your GS3!
Anyone having issues with dropped service? I have been unable to send/receive phone calls, send texts, but I can receive texts. My phone says I have 4g, and I'm connected to wifi, but they still won't send. I have tried wiping cache, memory, flashing back to previous nightly builds, even factory resetting but nothing is working. I'm currently running the latest nightly froms 9/6/12.
I had a slight issue with that on the 9/05 build, except mine showed no service at all.
Was that resolved by updating to a new nightly build? I've tried a couple of different ones, but nothing seems to be working for me.
My battery has been pretty bad on CM10.....anyone else notice the same?....I'm getting like 6-8 hours 2 on screen running 8-16 still
Sent from my SCH-I535 using Android Central Forums
I do notice that the battery drains quicker than an ICS/TW based ROM. Could be with the kernel or just because they are still tweaking the hell out of it.
Yea makes sense...I'm fairly new to flashing ROMs and hacking my phone...how long does it normally take them to come out with a so called stable build?....I think CM10 is fairly stable now but I'll be honest I can't wait till all the bugs are ironed out.
My battery life is noticeably better on the 9/2 build than it was on the 8/31 build.
What other bugs are you experiencing?
Nothing that has really bothered me too much. I notice the screen flicker every once in a while. After booting I get a force close notification for one of my widgets, but it works perfectly fine. GPS sometimes takes a minute or two to lock on. Other than those few problems it has been running great for me for the last few days. I've heard that NFC is now working, but I haven't had a chance to try it out.
I've been running a clean install of 09/08 for about 24hrs now and almost everything so far seems to be good for me. The one thing that is still annoying for me is the loudness of incoming calls and not being able to control the volume very easily. I had been running an 08/16 invisiblek kang build for a while and that was actually running pretty good for me, but I decided to try a newer build to see if issues were fixed. I'll stick to this one for a few days and then switch to a newer one. As with all of the nightlies that have been coming out there are usually improvements, but sometimes there are more bugs to deal with.
Good to hear, I am considering going back to CM10 with the newest build that they came out with today... 9/10/12 which is now in the OP.
CM10 M1 working well on my SGSIII. Haven't encountered the data issues I had with the August builds I last tried.
Sent from my Thunderbolt with a 4.3-inch screen and LTE
After a couple of days of running 09/08 and then CM1 I had to switch to another ROM. I couldn't handle the deafening loudness on every incoming call. Adjusting the volume seemed way too difficult a task for something that I think should be very easy. I'm running Bean's Custom Stock Rom Build 11 now and all seems well, granted it isn't based off of jellybean like CyanogenMod is. I hope to check back soon to see if any significant fixes have been implemented and then I'll try again. I think CM10 is coming along great and once all of the small bugs have been worked out, it will be one of the best out there (Also it should help with AOKP Rom's which are also awesome).
I'm running CM10 M1 version. So far everything is working great except I cannot get Google Wallet to reactivate (I reset Wallet before flashing). It just sits and spins while "activating account."
Anyone have any Wallet suggestions? While it's a cool idea, and handy when it works, I've had nothing but trouble with Google Wallet.
Bry
