[ROM] OUTDATED THREAD -= Dark Sense ROM v.1.1 =- 8/22/11
Status
Not open for further replies.
Re: [ROM] -= Dark Sense ROM v.1.1 =- 8/22/11
DO i just place that on the root of the sd card and flash it?
Yep, just download place on root of sdcard,boot into recovery,wipe cache and dalvik then flash,reboot after and give wifi a go let us know if that works.
Yes. I would also clear dalvik and cache as well.
It's weird but not suprized with htc anymore.lol The kernel should really boot on any version 2.3.3/2.3.4 not much would of changed probably main changes were something in ramdisk if any. They probably just update kernel version not making any major changes but the change from 2.3.3 to 2.3.4 would mean have to have new modules. I wouldn't be shocked if you took the boot from 2.3.3 and made small changes it would probably boot.
Hmmm... If that's the case then we need your help! Noe on has been able to get a 2.3.3 kernel to boot on a 2.3.4 ROM. If you can figure that out you will be king!
Did you say you dont have a 3D?
Nope i don't have a 3D but i get to mess around with one every now&then:)
I might just have to look into it,be a little tricky to do without the phone.
Yeah, I understand. It would be nice to open up all the overclocking kernels that no longer boot with 2.3.4.
I installed that Zip and it seemed to fix everything but then it would find networks but not connect to it kept saying obtaining IP address but it might be my home network??? I'm re installing the ROM just in case
check your router as well... just to be safe
Did you wipe cache and dalvik before installing the zip? Also, try a simple battery pull. I have seen that fix this issue believe it or not.
NOTE: Re-installing the ROM will undo the zip I just made!
Does wifi turn on? Or does it error when trying to turn it on?
If he can get to obtaining IP address then its authenticating to the network?
If wifi turns on without error its your network.
Yeah, like Jon said, reboot router and also do a battery pull for 10 seconds on the device...
Tried everything i could think of rebooted router, tried connecting to my other router, Tried WPS it all fails but i can connect on your ROM so ima just switch back to it appreciate all the help
That is super crazy. I still wonder why that is...
Its booting up now... But I do know this for sure... That boot animation is sweet!
Well....
I flashed your latest over my latest and I had no issues with WiFi... Everything was smooth!
Status
pitterhealth
