[ROM] [PORT] MIUI pureview
Re: [ROM] [PORT] miui pureview
To port this, did you just replace Apps, framework, and Media?
Sent from my HTC One V using Tapatalk 2
To get themes to work make a folder in data/system and name it theme.. I just tried it.. it worked
Download Solid Explorer. Go back and click data. Allow root acces.
Next to to Data/System. Here, create a folder called theme.
Is this like the HTX MIUI rom, in which all images in the rom are resized to mdpi? If not that could be something to add for an update.
No not everything is resized, but most of it is. And in the next update mms will be fixed, you won't have to manually set apn, you won't have to make theme folder, and some tweaks and apps will be added. I'm sorry but I have been really busy
Thanks, I'll try it out soon. And it's quite alright, take your time. I'm interested to see what you'll cook up.
Well I got a small update. Fixes themes not being applied. You no longer have to make a folder.
Its uploaded and ready to be downloaded
toolman61
