[ROM] Reborn ROM v2.1 5/13/11
yes ... you need to mount /system as r/w. As stated in the changelog, this ROM accepts sysrw and sysro commands. Open terminal emulator (provided with the ROM), type "su" [hit enter], grant it root permission, type "sysrw'" [hit enter]. Your system is now mounted as r/w.
I tried the sysrw command and.it still gives me the same error..tried rebooting too still nothing
I am sure if 3G was not working, someone would of reported it by now. I only get 2G will I live, so someone else will have to confirm for you. But I expect, its working.
I'm liking it so far. Not much lag. No idea how to use the tweaks though.
Sent from my VM670 using Tapatalk
3g works well, seems to come on quicker than other roms too. Been using this rom for 2 days, so far it's the best rom I've used Thus far. In 6 hours of sleep with 3g off, I only lose 1% battery. With about 18 hours of heavy use, wifi/3g, some gamin, and lots of kakao chat, my day ends with 45% battery. Great rom.
1% in 6 hours is impossible, your battery needs calibrating.
Anyone else having system rw issues or knows how to fix it? sysrw command doesn't seem to help.
Upcoming update? Been lookin for this in a 2.2 rom, would love it more if bluetooth was replaced with 3g widget. Or as is would be incredible. Anxiously awaitin this if its a preview of an update. This wouldve been the only reason to switch to aosp rom 2.3 since it saves me widget room.
Yeah 3g would save me some time. Its actually the reason I use aosp
dumpsterrentals89
