[ROM] Reborn ROM v2.1 5/13/11
Nice, can't wait. Much better than other roms out. Only question I have is, will we need to wipe to install, or flash over?
Sent from my VM670 using Tapatalk
But can it run Crysis? ;)
Well, according to my highly accurate benchmark scores, it can indeed run Crysis as well as well as encode xvid movies while burning CD's on it. Unless... I'm not doing it right. :(
Nick7, amazing support for options being included in Nameless. Thank you very much for the update and ongoing work.
-K
The only time you need to wipe is when you are experiencing issues with the ROM of coming from a different ROM.
In the events of updates, no you don't need to wipe.
And Crysis suckz, GoW for life!
okay that's good to hear. Asked cause other roms usually ask to wipe for good faith.
Nick, this ROM looks pretty amazing! Thanks for all your hard work developing and porting this over. I think I may finally switch from Rodimus.
Quick question, I saw this mentioned in the 1st page but not sure it was answered. Are your Optimus S themes compatible w/ this rom on the Optimus V? Can I just flash them in recovery or do they need to be modified in some way first?
Nooo, please don't flash those yet. I should probably mention that in the OP.. But yeah I will eventually port them over to the V, I just have like 6 projects going on right now. But it will get done
Just wanted to provide a quick update since nick teased you all, and what a great tease that is huh? :p lol. Were theming and buttonizing power control now so it matches our existing theme much better, making some tweaks to our existing theme, testing some battery changes, and doing some general code cleanup (stuff we shoulda caught the first time). Once everything is sorted out we want to run it for a good day or 2 each to ensure we've achieved the desired results then we'll release.
Sit tight and enjoy.
Reactions: jmel
Thanks for the work you're putting in.
KSmithInNY, sounds great. And yes, what a tease lol. I look forward to testing it out in the next few days (or when it's ready).
Is there any chance of the HID functionality on Bluetooth from 2.3 can be worked into this ROM or maybe made into a flashable update to the Bluetooth stack in any 2.2 ROM? I am really just wondering if its even possible or if someone knowing how might want to try. I am willing to test since I have all the devices in question.
Works good just can't get root uninstaller to work to get the programs I don't use deleted
Any way to get an option so that the front keys can be pressed to unlock the phone. I know this is minimal, but I forget all the time to use the top button.
Franci
