ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Re: [ROM] Reborn ROM v2.2.2 - 6/28/11
That makes good sense, but...lol...the percentages are so small that it doesn't give me any text. The color bar to represent the percentage graphically is so thin I can barely see it.
Top items are Android System, TasKiller, Swype, Facebook, and Calendar.
Now I'll tell you what...it's 11:51AM for me, and the phone has been unplugged for about 3 hours now with BT on and WiFi left on, and it's still 100%. So...oddly today the battery drain is now significantly less. I'm going to put 3G back on full time and see how it goes.
Reason I brought this up originally is working from 2.1, I noticed that I had BT, 3G, and used my phone for music (DoubleTwist), and I thought the battery life was spectacular. So...to see this sudden change triggered a warning for me.
Is it possible the phone hardware "warms up" to the newness of the ROM and then settles in?
You'd be better off not using taskiller
This might be a dumb question, but if i flashed a Reborn ROM v2.2.1, and I wanted to update to Reborn v2.2.2 without losing any of my data or apps, how would I achieve this?
Just wipe Cache and Davlik Cache and flash. You don't need to do a full data wipe when flashing 2.2 over 2.1.
Can I uninstall the LS670_Roaming.apk since I never use the app with Titanium backup?
Or is this app necessary to run on this phone's ROM?
So basically I just boot into my recovery, wipe the cache and davlik cache and just flash/install 2.2.2?
I just realized something...I've never seen the 'new voicemail' notification icon, with RebornROM?
Does this feature need to be activated?
Sent from my Reborn LG Optimus S using Tapatalk
Still playing around, but seems to work great.
Thanks for all your hard work, I too like the wakeup on the back button, I'll try the update.
What does that app do? Im curious...
It forces your phone to roam when needed......Very useful if your in an area that doesn't have good Sprint service....
Sent From My Super Awesome, Over The Top Optimus S.........Tapatalk......
I'm having problems with my downloaded apps not showing up in the android market after flashing Reborn v2.2.2. Anyone encounter anything similar?
Like, only the apps that come with the ROM show up under the My apps section in the Android Market. All my other apps don't show up under the My apps section and can only be found by individually search for them in the market. Does that make sense?
Also my call log is completely gone and the shortcuts I had for contacts were completely mixed up and essentially worthless. This isn't a huge deal, but just curious if anyone else had this problem.
You are technically on a new rom. So all that is gone. Its as if u are a new user. This is to be expected and peeps use titanium backup because of this...
Sent from my PC36100 using Tapatalk
Reactions: heathspawn
Problem fixed. Sorry, I forgot to backup everything with Titanium Backup before flashing. Thx
Status
WarrMads
