ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Re: [ROM] Reborn ROM v2.2.3 - 7/17/11
Upgraded to. 2. 2.. 3. and experienced serious slow down and lag across multiple flashes. Reverted back to 2. 2. 2 and am now running as smooth as butter.
Keep up the good work. I'm very grateful for the development community for this phone. :-)
Nick:
I noticed that after enabling Google Latitude on my phone, my phone's battery life has been draining at a rate of about 3.5%/hr (from ~1.5-2% before in 2.2.1). From what I see in SystemPanel, nothing looks especially weird, except I believe there is some wake lock probably involved in updating the location. I see that with Smartass enabled, the awake_min_freq is set to 400Mhz. So near idle, my CPU is running at 500Mhz. I tried putting this line you had in 2.2.1 back into 99tweaks:
echo 0 > /sys/devices/system/cpu/cpu0/cpufreq/smartass/awake_min_freq
But it doesn't seem to have taken it - upon rebooting and doing a cat on the file, the value is still 400000. What I can do though, is to go to the adb shell, echo a 0 into it, change governor to ondemand, and then back to smartass. My near idle frequency then dropped from 500Mhz to around 250Mhz.
Just FYI, it seems some of the other values in the 99tweaks (like sleep_max_freq) is also not taken up by the smartass governor (upon cating, it shows a value of 320000, instead of 245760 - perhaps you want to take a look why this is happening?)
Thanks.
Sorry, I wasn't clear. When I switch to OnDemand, it switches back to Smartass on both programs. I've tried rebooting (with the "apply on boot" box checked) and applying the change without a reboot and it invariably switches back to Smartass by itself.
Hey, I have the same issue. Whenever I change the governor and/or the frequency in SetCPU, within 10 seconds, it switches back to '748 max 245 min' with scaling 'smartass'. I tried a full wipe and flashed the zip, the issue was still there. Were you able to resolve this?
I don't have this problem, although I don't use SetCPU, but rather just an echo on adb shell to change governors and speeds directly. Also, I have deleted that collins shell script so that might make a difference...
Re: [ROM] Reborn ROM v2.2.3 (No mobile network after using WiFi)
Hello gentlemen,
I'm new to the Android OS and smartphones (my third cell phone in 9 years) and have only had my phone for about 10 days now. I've learned quite a bit already and jondevere has spent a LOT of time with me un-f*&^ing my Rom Manager install. I do like the ROM BTW. Its not going anywhere anytime soon!
My issue is whenever I use the WiFi and turn it off I lose mobile network. I can connect to gmail, market, and everything without WiFi, use it then turn it off, then the mobile network wont connect me to anything. I updated PRL yesterday with jondevere and didnt use WiFi again because that seems to cause the problem. I reboot and it works fine again but I would rather not have to do this every time I wanna use WiFi but I am able to work with it. Is this a known bug or is there a 'fix' for it? I take PMs and have Gtalk if needed.
Ok cool, that was it. Disabled collins shell script, rebooted, and all is working in SetCPU. Thanks man.
Keep getting connection error. Any ideas?
I have a similar issue. So far all I can do to fix (band-aid) it is to reboot. Works fine till I use WiFi. Is your problem identical to mine?
I no longer have this issue. After Titanium backup/recovery and updates everything seems to work fine.
Good morning...
I have 2.2.3 installed with Collin's batt tweek running...
If I do a dirty flash of 2.2.3 again will that disable Collin's batt tweek?
You don't want to use Set CPU and Collins_tweak at the same time... they don't play nice together, which is probably where most of the problems came from.
Just an FYI that Nick7 has confirmed what I'd suspected previously, that the collin_ph mod is enabled by default in 2.2.3. If you want to use anything like SetCPU to modify the CPU speed yourself, it's not going to work right with 2.2.3 unless you manually disable the tweak (I'm assuming instructions are in the collin_ph thread for that). Stick with 2.2.2 for the time being otherwise.
EDIT: okay, looks like running:
su
batt-cfg
and choosing option "8" will disable the tweak.
Reactions: Jessicalt1
and choosing option "6" will disable the tweak.
So, is the Collins mod arlready installed in 2.2.3?
I could not get 2.2.3 to flash correctly from a fresh data wipe.
Yes. It wasn't meant to be, but it was accidentally enabled by default.
Okay, after trying that myself (flashing 2.2.3 and then choosing the "Disable Tweak Entirely" option from the batt-cfg menu), that doesn't seem to work right. Choosing option "8" to disable it just results in it saying "Exitting without saving..." and alogcat still shows collin_ph running. Oh well, back to 2.2.2 again.
Seeing the same behavior. Is there a way to get the 2.2.2 file still?
Somewhere around here, Nick posted his public Mediafire link... check there.
I've had the same problem ever since I upgraded, I didn't like how slow my phone got at low percentages and turning it off never worked, it just told me it exited. I am messing around with a different rom but luckily I saved Reborn 2.2.2 lol.
Yeah I accidently enabled collin ph by default. If you are experiencing problems relating to cpu governors, frequency, or lag that's why. I'll fix it soon. For now you can use 2.2.2 my mediafire folder is linked in my sig.
Nic or someone can you please post 2.2 link.. The lag on my optimus with the new one is a pain..
Thanks again!...
EDIT.....
Wow go me for freaking reading post.. never mind my last post.
You can do 'batt-rm.sh' after mounting /SYSTEM as R/W. That will take it out completely. More info at http://forums.androidcentral.com/lg...hacks/102280-mod-collin_ph-battery-tweak.html.
Status
Arwen
