ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Re: [ROM] Reborn ROM v2.2.3 - 7/17/11
does this upgraded rom include gingerbread? ima bit lost, some some threads talking about official 2.3 update for the sprint optimus s
Thanks all for the new ROM, been slacking on keeping my fiance's phone up to date, its still running ThundeRom 1.8.3 :\
Keep on kicking arse! :cool:
Anyone else have a problem where after the boot screen is done it'll just go to a black screen? Happened twice and each time I had to remove the battery and restart it to get it to work. Both times happened after recovery, but after I remove the battery and reset it works fine. Just weird.
Had the same problem, but only after setting up link 2sd.
Thanks for the update! I was hoping a clean flash of this ROM would solve a few problems I've been having but it didn't.
1. My phone has trouble connecting to my home wifi network. It doesn't seem to have trouble with any other networks and none of my other wireless devices (including my wife's stock Optimus) have the same problem. It doesn't seem to be able to pull an IP address.
2. The phone seems really slow. Scrolling between screens and through Facebook posts is somewhat agonizing.
This is on a fresh flash after a full factory reset, although I was having the same issues on 2.2.2. Does anybody have any ideas? Is my phone dying?
Anyone know why I might be having trouble accessing settings in the music app?
Nevermind, I got it. Enabled Stagefright.
Just an update on my post from an hour ago. I fixed the wifi by resetting my router and I discovered that the slowness goes away as soon as I plug the phone in. Any ideas?
I wiped clean everything, then flashed the rom and my home button doesn't work
Smartass scales up when it's plugged in. Try changing your governor to ondemand. Smartass is more geared towards power saving rather than performance.
Reactions: psaurus81
How do I change that? Do I need to re-install SetCPU?
no frills cpu control from the market works as well
Awesome. Thank you. I already own SetCPU so I'll use that and report back on my results tomorrow. Thank you for your hard work and for supporting your ROM so well.
Hey I was just wondering what the curved arrow with the slash through it that is right next to the volume/brightness setting does. I have read almost every page and cannot seem to find it.
That switches on/off whether your phone's screen will go to landscape when you turn it sideways (via accelerometer). :)
EDIT: nvm hadn't refreshed my page thought this was still relevant, glad someone answered him though
Another update: Neither SetCPU or NoFrills will disable Smartass governor. Is there another way around it?
Status
Machetaseo
