ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Works the same minus the ability to integrate your phone number for texting through gv................
I disagree, I integrated mine just fine, although I hadn't been able to beforehand. I think it's a Google/sprint issue, not a rom issue.
Ah, hmm. I could do it on cm7 but it never gave me the option on reborn...would be kinda neat if it did I'll have to try it again.
any way to save my dictionary and saved words on the keyboard? i want to do a clean install but don't want to lose them :-\
use titanium backup to backup the keyboard's data, then restore the data after the clean install.
Reactions: itony
on a fresh rom with my blueant q1 i have to pair then unpair and pair again to get bluetooth stereo working this was on stock and reborn.
What Bluetooth mono app are you using to play music thru your Bluetooth headset? Have you tried BTmono, works great there is a free and paid version. Currently I using the paid. Works so well it even works with CM7.
sent from my CM7 gingerbread Optimus S
i have a feature request which is probably really difficult to implement, but it's worth a shot.
the "Sixaxis Controller" app was recently released on the market, which lets you connect a playstation 3 controller to an android phone using bluetooth.
unfortunately, Sixaxis Controller requires the L2CAP bluetooth protocol, which Reborn doesn't support. drew's CM7 stable, however, does support this protocol.
is there any chance the L2CAP protocol can be added to Reborn or no?
It should be known you cant flash this Rom if an Optimus S has clockwork recovery.
I know we have a sticky that states not to use the rom manager. I never read that until seeing it today and i have been running clockwork for over 4 weeks. Regardless it flashes a cm7 rom fine but not roms from VD source.
I flashed my recovery back to zefie and all issues were resolved.
How about a ROM repartitioned for more program [application] space?
Unfortunately the risk is not worth the return :( major brick risk on both user and developers end. If you need extra space you can check out a2sd :)
I think just an update with all the updated GApps might be nice say once a month or something. Makes it simpler to just reflash without having to update Gmail/Maps/Youtube/etc.
How about a way to use data2ext on reborn would be awesome!
Always happy to help, hit that thanks button if I did
You can use data2ext u just have to load the ext modules, i have posted how to do it... Downfall is it seems to kill my battery alot faster, probably from reading sd card constantly, currently I have been using reborn with pica enabled ext4 to use links2sd so i can choose what to move...
i know there are apps to do it but maybe a built in way to search your contacts and when you dial it auto picks up who you are trying to dial or you can even spell your contacts name out with the number pad?
my phone has this phone and it has not been working ...the rom is great ...except for the internet..it never works. anyway to fix that?
Status
pamatika
