ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
i got ignored the 1st time i asked this question, so im try again, how do you over clock with this rom?
I finally was in my car where my Bluetooth device is (motorola rokr t 505) and had no issues. Activated BT on the phone, turned on t505, they immediately connected. Made a test call, received a test call, streamed music through it all without a hitch.
Guess it might be my headset or I just need to clear cache/reboot. Thanks for double checking.
Sent from my Nonamed LS670 using Tapatalk
I've bolded and underlined the step from post #1 that i believe you missed. My guess is you flashed the ROM, skipped step 5, flashed noIQagent.
I did that the first time when the correct themes for the Rom were posted, so I started from scratch (even wiped my SD card. Whoops! Haha). Still had the problem when flashing the the theme instead of noIQagent. Oh well, the Gingerbread theme works. So I'm a happy camper. :-)
On a different note, is there anyway to do a lockscreen like on CM7? Where you can go straight to sms or phone? Is that impossible to build in?
I suspect Sprint is having problems. I received 3 MMS yesterday and sent 2 without problem. This morning someone sent me 2 pictures and they wouldn't download. I tried to send a pic at 6:05pm (ET) and sent no problem and they got the pic. The user tried sending me a pic and i never got it. I tried sending them a pic again and it failed this time.
Whew :eek: I thought I was the only one havin' a problems w/Pic Mails too.. did not want to think it was NamelessROM since I'm loving everything else about it!
I figured maybe an overload due to the holiday weekend???
Ya I've had issues with mms also. Thanks Sprint.
Sent by Tapatalk ----- Optimus s
dont know if this make sense but restoring my all data using Titanium backup with all the settings and program isnt going to effect this rom right? as long as i dont install the sprint crap?
I would do just apps and data. I had issues with restoring settings. So I would manually put those back in.
Awesome awesome amazing ROM! Everything is great.. Only thing I want to change are personal preference things like icons. I guess I'll learn how to do that after finals, but seriously, the ROM is great! Yall did a really good job on this one.
So, everything I had a question about was answered in the first two posts. Well done Nick. Tested mms and bluetooth, both work for me.
As Nick7 stated, the ROM comes pre-overclocked. Also, it features a great overclockable kernel so SetCPU will work nicely if you want to go higher.
When I forward an email its blank. Never had this issue before. Doing everything the same... any help???
Alarm clock bug/issue?
I apparently slept through 2 alarms this morning?
Not normal.
I turned on the phone at 5am, and the clock still staid 3:40am, then updated to 5am a few seconds later. Could this be messing up the alarm clock app?
nameless rom 1.0
I thought the same thing, but i just forwarded myself an email to my other address and even though it appears to be blank when I look in the "sent" folder, it is not blank on the receivers end.
Details were light so i made some assumptions that i believe cover all bases.
1) Using stock email app, forwarded email with no text entered in the body. Received no problem and everything previously in the email was visible.
2)Using stock email app, forwarded email with just my signature in the body. Received no problem and everything previously in the email was visible.
3)Using stock email app, forwarded email with text and my signature in the body. Received no problem and everything previously in the email was visible.
4) Using gmail app, forwarded email with no text entered in the body. Received no problem and everything previously in the email was visible.
5) Using gmail app, forwarded email with just my signature in the body. Received no problem and everything previously in the email was visible.
6) Using stock gmail app, forwarded email with text and my signature in the body. Received no problem and everything previously in the email was visible.
If i have not hit your scenario above let me know but i feel pretty confident it's not a ROM issue.
Not normal.
nameless rom 1.0
My alarm sounded at 6:00 am no problem followed up by my second alarm going off at 6:30.
Did you make sure the alarm volume was turned up? Menu > Settings > Sound > Volume > alarm
Did you make sure you have the alarm set? Have you tried setting up a test alarm for say ... 2 minutes from now?
Regarding your clock concern. I can only assume your talking about a widget having the wrong time, not the system (in the notification bar). The system clock is kept by the network and is pretty much accurate down to 10 seconds. Widgets on the other hand poll that system time which is where they get the time to populate the widget. If the widget doesn't poll fast enough when you wake up the phone, it will still show an old time, the time for the last time it polled to be exact. Thats something you need to talk to the widget developer about, not the ROM developer. Also, that would not impact your alarm at all because alarms are based of system time, not a widget that polls system time.
I'm using goweather as my clock widget and have no had that issue but have had the issue on fancy widget (on this phone) and the HTC clock widget back when i had HTC phones.
KSmith, in stock email app, look under your "sent" folder. Does the first email you just sent appear to be blank? Mine did, but on the receiving side it was all good. It threw me off at first. No biggie though.
I just wanted to say great job on this ROM. I ran it for a few days with no issues, but switched back to aospCMod just because I like Gingerbread and I can use data2ext with it for more space. I currently have 278M worth of apps and growing so I needed a lot of extra space. I know I could use apps2sd, but it still doesn't seem like enough. Anyway, the ROM itself ran very smooth and everything I used it for worked correctly. Keep up the great work and I hope to see more from you guys!
Reactions: KSmithInNY
Exactly how i sent it and exactly how i received it, all text is visible. Are you not using quoted text?
It could be user error, or i could of slept through it, but I didn't think it auto shuts off.
I don't use a time widget because i have it in the notification area :)
So I was talking about the notification time, which I thought was strange.
Not sure if anyone else has had this issue, but I just bat pulled and my phone thought it was Jan 5th at 7pm. I bat pulled again, and the same thing. Tried another and it finally fixed itself. Anyone know what could be happening?
Status
gurusdex
