ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
gsm.operator.alpha=changing me breaks Sprint apps.
So if we don't care for our sprint apps to work, we can edit our drop down bar to say something other than Sprint still?
I'm also coming from TR and liked the feature of having it say something unique...
Andddddd............... did the themes just disappear from page 1?
EDIT: Seems the instructions have changed to exclude the themes also...???
when i was trying to figure out how to change the notifications text header, i looked in the ThundeROM build.prop and saw that ro.cdma.home.operator.alpha was changed to "ThundeROM", not gsm.operator.alpha. i then edited the corresponding value in the Nameless build.prop and got myself a custom notification header.
since i'm pretty sure sprint apps worked on ThundeROM, if you want to keep using them edit ro.cdma.home.operator.alpha instead of gsm.operator.alpha.
IQAgent
Just curious:
I have a pretty stable setup right now with TR 1.8.3, so I'm not really in a rush to switch yet, but I would LOVE to get rid of IQ Agent.
Will this "NoIQAgent" patch work with ThundeROM, or is it specifically built for Nameless?
That's odd. Hope it's not because of a problem. (I planned to flash this tomorrow.)
Luckily downloaded a copy of the minimal black and TR modded version (without clock and black menus) before they came down.... Should have grabbed them all :( If you want one of the two that I have, and nobody is against it, just send me a pm and I'll email it to you or something. :D They really are great themes. Hope to see the rest back up soon! :'(
I did already download the files I wanted, but I'm more curious why they got pulled down. Makes me think there was a technical problem of some sort.
having problems enabling stagefright. get "sed: can't creat temp file /data/local.propBY1gbu: Permission denied
I was having the same problem until I realized that I forgot to enter "SU" (without the quotation marks) when I opened the terminal emulator.
Reactions: jjairal
This probably won't be an issue for many people, but just reporting that the only 2 times I've experienced a lock up with this rom was when I was running that file explorer that was packaged with this rom. it seems to not like it when I am accessing lan samba file servers. So far estrongs has been doing ok for me.
Loving this Rom, thanks guys. Got a bug to report I thought it was fixed in the stock Rom when BE was released. When I activate my Bluetooth head set I have to connect 2 times to get it successfully connected and useable. So I turn on the phone Bluetooth once on I turn on my headset and it does not connect, so I turn it off then turn it on again and then it connects correctly.
Sent from my Nonamed LS670 using Tapatalk
is there something we can flash to make all the buttons turn on the screen instead of just the power button? (just like with Thunder ROM)
oh yea and can i assume that JIT and Hardware Acceleration are enabled by default?
Enable Bluetooth on the phone first, then the Bluetooth device. Not the other way around.
There is a button layout link in the OP.
Sent by Tapatalk ----- Optimus s
Will we see themes again? I liked being able to switch mine up every once in a while. Thanks again guys!!!
Status
spade20
