^^^Does this voice dialer tweak also make the stock buttons wake the phone?
But they ARE working and I did NOT flash buttonwake.zip. I don't want them to work, like in TR. Just wondered why they were working as I thought they were set to NOT work just like in the last TR I was running previously....
Guess I will reflash and see what happens...
This may be a really dumb questions so please feel free to say so. Does the use of the WiFi Hotspot App in this ROM require you to have the $29.99 a month mobile hotspot service from Sprint?
I just had a pocket dial, and I noticed that my buttons are waking the phone even though I never flashed the buttonswake.zip, any other way I could have tripped this? I'm very confused?
Having the same issue here, did you ever figure this out Warlord?
Kamron said:I just had a pocket dial, and I noticed that my buttons are waking the phone even though I never flashed the buttonswake.zip, any other way I could have tripped this? I'm very confused?
Kamron said:Having the same issue here, did you ever figure this out Warlord?
Nevermind, I reflashed the voice dialer tweak mentionned above, and I have confirmed that it also causes button wake. If there is any way to avoid this, please let me know. Thanks!!
For the time being, I think I'll revert to TR because that worked the way I really liked.
Yep I forgot I flashed the voice dialer.zip too... that's what it was... Reflashing at the moment. And I was also getting poor battery life too.. It was awesome in TR. Not going to flash anyhing beside Nameless and the same theme I was using ( Steel my Elegance) and see how it responds...
Could you elaborate on "poor battery life?" My device holds a 100 charge for about a day and change with lots of accessing of the internet, facebook, the works.
To get Voice Dialer without doing that flash, read this
Duh!! That makes sense!!! Sometimes it helps to actually read the WHOLE post! lol Thanks for pointing that out!![]()
Are you saying that your phone holds a 100% charge for longer than 24 hours, with use!!! LOL!! That sounds a little crazy.We are talking about the Optimus S here right?
Unless I'm very mistaken, I think he's saying that, given a 100% charge, his phone will hold on for a bit over a day. That is to say, it will run out of battery after a little over a day.
If he is indeed saying he holds AT 100% for 24+ hrs, then either his phone is lying or he is, but I think it's just poor phrasing.
coming from the latest TR. is it easy to flash this rom right over it?
