ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Are you saying that your phone holds a 100% charge for longer than 24 hours, with use!!! LOL!! That sounds a little crazy. :confused: We are talking about the Optimus S here right?
Fine print: it's powered off.
Mine tends to hold at 100 for a few hours, but I assume it just means I ought to clear my batt stats.
You may have issues flashing this over the top of any previous ROM.
From the OP:
1. Download Nameless ROM. Do not open it, do not extract it, do not rename it.
2. Place on root of sdcard
2. Reboot to recovery.
3. Wipe data,cache,dalvik
4. Flash Nameless ROM.
5. Let the ROM fully boot.
6. Download noIQagent.zip
7. Reboot to recovery.
DO NOT WIPE DATA DURING THIS STEP.
8. Flash noIQagent.zip
9. Reboot and enjoy!
thanks, appreciated!! im hearing this is one hell of a rom...making the switch
Drag & Drop whatever app over the icon that you want to replace.
Side note: Great ROM! stable, and quick. I love it. The only thing I don't like is the keyboards. Swype takes up so much of the screen (awesome keyboard though) so I don't really use it, and the HTC KB seemed to kind of do it's own thing some of the time. I ended up just installing the Gingerbread KB, which is working well. I usually use the stock KB anyway.
Stoked to see future updates!
Anyone else use the SlideIT keyboard? Kinda like Swype, but much more stable, faster, more robust and user friendly (and without all the silly pop-up notifications)
If you like the sliding type keyboards (which I LOVE) check it out.
Most day's, I work in a basement at work... and my phone has TERRIBLE reception...
I take my phone off charger around 4:30 every morning and I'll be down to ~ 30% by ~ 2:30 in the afternoon... (but that's again, with very crappy service). That includes having bluetooth connected for ~ half an hour on the way to work, and being connected to wifi while @ work, checking e-mail, and facebook periodically, playing card games at lunch time, and periodically texting with my wife during the day...
Today I spent ~ 3 hours down stairs, and the rest of the time in a different building and had ~ 68% battery left by ~ 4:30 pm...
During the weekends, I usually see around 25-30% battery drain during a full day... but there's minimal phone use during that time.
For the past two months I have been working on a jobsite at one of the mines here in southern AZ, and I also get horrible service. Nick7's Roam app doesn't even help much. Bad service is definitely a battery killer. Charge on the way there and charge on the way home. But if I have service I can go all day (starting at 5 am) and still have at least 60% by 10 pm. Unless I get "flash" happy in the evening. LOL
stuck on android boot screen.. dono wat i could have done wrong.. wiped everything before flashing no rom.. it says not to wipe data when flashing noIQagent.. do i wipe everything else?
I bet you did not let nameless fully boot before flashing noIQagent.
I'm finding that my available space steadily creeps down to the point of getting a running-out-of-space notification. When I reboot I have 136MB free space, but when I get the notification I'm down to 15MB of available space remaining. I'm not necessarily concerned, as I can easily reboot my phone every morning to avoid this, but I've never got this notification with ThundeROM while using the phone in the exact same way and I would go a week or more without rebooting.
Anyway, not a big deal, but I was just curious if anyone else was finding this or if there was a reason my memory would creep down faster with this ROM than other ROMs.
My cell lost data connection last night. I did a wipe and went through the install process again but still nothing. Yikes!
is it possible to get the DSP manager on this rom, in order to increase speaker volume, or is that only possible with CM7?
I know there are some hidden menu settings that affect audio, not sure if anyone has played with them.
My bad, guys, I didn't phrase that very well. I was just wondering, I'm usually around 10-20% battery life by the time I go to bed after a day's worth of usage (meaning, my typical 8am-midnight+ day). I hope that isn't more confusing. xD
Status
heritagevine08
