ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
I've deleted the old IQagent patch file, but now I have others I'm wondering about. I have upgraded through many ThundeROM and Nameless/Reborn versions. Can I delete the following from the root of SDCARD? I'm guessing their left from the Thunder days.
BuildPropDeluxe.zip, BuildProp-Stock.zip, and BuildPropStock_No-Jit.zip?
Thanks! That Recovery Flash screen is getting a bit lengthy...
Loving this ROM and about to try ReTouched.
Yep, those files are old now you can get rid of them .
Sent by Tapatalk ----- Optimus s
Reactions: Scott_L#AC
FYI, I just noticed when I did "Reset Category," it would reset my launcher apps to default. I have ChompSMS and Dolphin Browser on launcher dock to replace the stock messenger and browser. Since I download alot of apps, instead of moving them in the correct alphabetical order, I normally hit Reset Category and it sorts them for me that way. What I failed to notice was that it reset the launcher apps to default as well.
Now I know why it keeps reset the launcher apps to default. Initially, I thought it was something during reboot that caused it, but I've rebooted numerous times and it never defaulted back to stock messenger/browser.
Hope this helps those who are having this issue. I left both apps on the phone and did not move them to the sd card..
Ok I love this Rom and my wife wants to switch from cm7 to reborn. How can I do the vd update without going back to stock
Anyone else having "LG Home" freeze the phone? Never had this problem before on any other rom or Nameless v1. Seems to happen more when im using wifi on my phone. Sometimes I can get the force close thing to pop up but it will just freeze again and not let me press it. :(
Just had it happen again right after I posted this. Not sure whats going on, I didn't see anyone else post a problem like this.
Maybe wipe dalvik and cache and reflash the rom.
It was placed on the sd card automatically when reborn v2.0 was flashed. But maybe you never flashed v2.0. ;)
So, here you go:
noIQagent.zip
Also, theme reTouched includes the noIQ tweak if you are interested.
(Just figured I'd through that out there......LOL)
In my case, I actually had deleted most of the zip's on the root of my sd card. (little clean up) ... ;)
can't thank you enough bro. good work. however, as a complete foreigner to this process, it would have helped if the instruction "flash rom" had a little more info regarding how exactly that's done.. I had to look around for like 10 minutes before I tracked down an explanation... Anyway, just coming from a complete and absolute newb.
Has anyone had a problem with the phone not booting up past the LG screen if they let their battery go completely dead?
This happened to me in ThunderROM and now with Reborn ROM v2.1. I ended up booting into recovery and rebooting from there.
It's not an issue, it's a feature. The phone won't boot until it has enough charge.
No worries... we were all there at one point or another... ;)
sorry for the ignorant post, but was this originally namesless rom? If so, I have nameless v1.0. Can I flash on top?
Yes it was. Some people flashed on top and it was fine, and some had issues. I recommend a full wipe to be safe.
In theory, yes. I'd suggest backing up apps with titanium backup and wiping data, cache, and dalvik. Seems to be smoother and battery life, for me, is better on a clean flash.
Edit: beaten to the punch
- Sent from my Optimus S
Status
nettirb
