ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Start fresh. You won't have any problems.
Sorry, I should have been more clear. My "UPDATE" post was a fresh start - wiped data, cache, and dalvic before re-flash. Still have the exact same freezing and rebooting issue. Have had a couple of freezes and at least one reboot today.
I redownloaded and now I am receiving the signature verification failed no i disabled that but now when I try to install it will begin, verify, start unpacking for half a second and then go black and reset back to the recovery home page without the ROM actually unpacking. Any ideas or is it possibly my recovery. I am using Xionia CWMA v1.2518.6 according to the top of the custom recovery.
Check your mD5 sum, against a posted one, if it is posted.
OK so i just switched from cm7 and loving this tom its smooth and nice features and it gets updates which is the main reason I switched to reborn
Hi guys,
I installed nameless rom on my optimus and overall I am pretty happy with the experience. I have only one issue. My phone no longer provides a notification of voice mail. I do not know how to get this functionality back, Any suggestions are welcome. thanks in advance
Hi guys,
Read post 2, VVM was removed in nameless rom and has not been added back into the subsequential releases of reborn.
Best recommendation is google voice as post 2 says, I believe if you look somewhere through the first 10 pages or so of the thread nick posted a link with the VVM apk aswell.
EDIT: I believe there was consideration of putting VVM back in in a future release, though I personally would be happy with google voice
I dont really know what this means or where to check one that is posted? Sorry, like I said, I'm really new at this. I just rooted my phone for the first time 4 days ago and before that have had no experience whatsoever. I tried searching to find answers but nothing I could find was a similar problem.
Does anybody like the stock gallery? I think it's slow and crappy. I wanted to replace it with "quickpic" on the market. Ideas?
Also, what do you guys want to see in the next release? Currently I'm working on:
- black mms
- native wifi tethering in settings.apk
- updating gapps..
- resizing mtd partitions?
- some other stuff I forgot.
Next release won't be for another two weeks though. Completely swamped with stuff right now.
Reactions: itony and twigge
If there's any way to modify sizes so that larger app installs don't fail due to lack of space that would be fantastic. I believe I've heard that it's due to dalvik cache being moved to the system partition instead(?) and this creates too little space in swap from time to time when installing larger apps. I know that Maps is one app that I always have to uninstall Facebook for first otherwise it fails due to lack of space during the install. With Titanium Backup, it's easy enough, but if it could be avoided altogether, that would be great.
Keep up the great work either way :)
Status
fasoli
