ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
I was researching this battery drain using Reborn 2.1. I've been losing 5-10% hour just texting and web. I even went back to a stock VD kernel, and still had similar drains. So I went back to ThunderRom 1.83, and it was a little better @ 5-6% per hour. So something still was draining it more than the rom I previously used. I had thought maybe the batteries have started to degrade already at the 6 month mark, but i still wanted to see what was causing this.
I think i found the battery draining bug. It is google voice version 0.4.2.24 . I caught it a few times spike system resourses and become very laggy and have to kill it. And i was losing battery life anywhere from 5-10 % per hour. I have since installed and older google voice version 0.3.4, and that has fixed any lag and FC. Plus battery life has returned to 1-2% loss per hour. The stock email program sucks battery life too.
So its not the Reborn Rom. But we have to use Google voice for the voice mail, so it is related to this rom.
Give it a try if you are having battery drain problems. Uninstall GV 0.4.2.24, and install below.
google voice 0.3.4
MEGAUPLOAD - The leading online storage and file delivery service
interesting. I'll have to give it a shot. I'll let you know how my battery life reacts.
I was wondering if there was a way to change the default browser in the launcher. I keep going to the launcher drawer and dragging the new app to replace it. But after a reboot it keeps reverting to the stock browser. Works for the navigation app I placed in it a well as moving the messaging app, but xscope keeps reverting
Move the browser app from your SD card back to internal storage.
Reactions: hlxanthus
after flashing reborn i have had no problems but today i went to use my sprint nav for first time since flash and i cannot access gps?...the icon from notification reborn menu is activated i check in settings manually if its active but still not able to get a gps signal....usually a icon comes on top of the screen when gps is initiated but there is nothing popping up that i can physically see that its on...has anybody run into this prob?...if so some help would greatly be appreciated.....oh and i also did a clean wipe and reinstalled reborn again same conclusion
Try wiping all and then re-flash Reborn v2.1. Wipe data/factory reset, wipe cache, then flash Reborn v2.1 again. It sounds like something went wrong in your last flash. Hope you get it resolved. Post again if you get it resolved.
Unable to connect to network
I can only connect to 1x after doing a clean ROM flash to Reborn (from LEGO ROM). I have tried another clean flash, dirty flash, pulling the battery, updating profile (will not update), even calling sprint to have them reset my network settings. What do I do?
tried reflash clean wipe but i still have no gps....any ideas?.....tried re-downloading reborn....put it on memory card..reflashed....same results.....JON does your gps icon come on when enabled?...thx in advance
Download GPS Status and Toolbar from the market
Go to settings
Pick Medium Lock on
Go to stats
Clear GPS Data
Then go into menu again and download gps assit
wait for a lock then exit out of program and retry google maps
A looooong time ago (8 months lol) I had a HTC Hero and on my phone relashing roms would cause my gps to get flakey this program helped with that hope it helps you :cool:
The only thing I can think of is updating your prl. Not your profile. Hope this helps.
Status
lucky_4_honey
