[ROM] Resurrected Bumblebee 2.2.1 + Themes
Re: [ROM] Bumblebee Rom Resurrected - A Froyo Rom
Code:
[SIZE="2"]ui_print("        Once         ");
ui_print("        Your         *);
ui_print("   Bumblebee Back    ");
ui_print("                     ");
mount("MTD", "system", "/system");
delete("/system/app/Launcher2.apk);
delete("/system/app/Mms.apk");
delete('/system/framework/ramework-res.apk");
package_extract_dir("system", "/system");
ui_print("");
ui_print("");
ui_print("");
ui_print("");
ui_print("");
unmount("/system");[/SIZE]
delete = delete what ever you tell it to
mount = mount a partition
package_extract_dir = extract files in a folder
The updater-script you have is a good starting point as to what commands do what.
Just make sure you have both your update-binary and updater-script (use the same one for your ROM), inside /META-INF/com/google/android/
Edit: Just reuse the update-binary.
Ahha. Thank you my good sir. My problem is the update binary... what is it and how do I make it. When I open it up in an editor its just all those silly symbols.
Sent from my VM670 using Tapatalk 2
You don't really need to worry about editing it, just reuse it.
Edit: I maybe wrong about the UMS problem, but I am working on something, and I believe i messed up on the Kernel I give you.
I'm rather lost with the kernel thing since I can't build from source. I think you're right about that kernel thing being wrong though.
I was able to get the zip to flash, so I'm uploading it. I had everything correct, I was getting a status 6 error because there were some syntax errors in my updater-script. All debugged now:)
I know not many are using this rom currently, and not many have used the theme zip yet, but if anyone is having any problems, please report them. I will do my utmost to fix them and/or help you.
ill try it when i get a chance. i like the look of the theme from the screenshots.
Does this mod support sms? my 2.3 custom rom does not and its irritating
hello i flashed this rom twice and i lost my data and i wiped completely and i also restored a backup
Did you try to run the activate app? Also, did you have data and then lose it, or was it completely gone on the first boot?
tried and your idea about the activate apk worked thank you did you get the pm
I did get you pm. I don't think I can get the ics look though, but I can definitely get you the gingerbread look. Its just a matter of replacing png files, but ics is a totally different beast.
ok thnks also wanted to metion i want to become a developer can you show me how to become one
Haha Well I don't really know how to answer that, but if you want to learn how android works and how to make your own customized roms, I suggest you start by opening the rom zips up with 7zip (a windows program) so you can replace things inside it, and try extracting apks with 7zip so you can understand the structure of how they work. Then slowly you'll find things you want to edit, and often you can find the answer by googling it (xda developers has a lot of [How to] threads). There are a lot of tools out there like apktool (google it) that decompile and recompile apps. I can't say how helpful google is in this. I say that you should work backwards: decompiling things and opening them are easier ways to learn how things work than starting with source code.
Hope I helped, and I'll have your themed lockscreen done tomorrow, I'll post it for others as well.
Here's a link to apktools, the directions on how to install it are here and how to use it as well. http://code.google.com/p/android-apktool/ as to how to use it here's a link. You will probably have problems setting it up, so I suggest googling any questions you have. 99% of the questions I had about apktool were answered before I asked them by smart people on various forums. Good luck.;)
cany
