[ROM] Resurrected Bumblebee 2.2.1 + Themes
Also: Questions about the ZenGarden recovery should be posted in that thread.
This thread is for things pertaining to the Resurrected Bumblebee ROM.
Flashed this last night and for some reason Market wont update to Play Store, and any app I download is literally downloading at 5-6 kpbs, as opposed to the reg 200-300kpbs. Very weird. Help?
Sent from my VM670 using Tapatalk 2
Did you download from computer or phone? WiFi or 3G?
Did you check the md5 sum of the downloaded ROM.zip?
What did you wipe and format in the recovery?
Which recovery do you have installed?
It will probably not check out good.Try downloading with WiFi.
Wipe everything and format (found in the mounts and storage option) everything but the SD card.
It checked out perfect, and I redownloaded it. So yea, all works fine accept starts downloading apps from play market and gets to 4 KB then pauses, after a while it'll start again but veryyy slowly
Sent from my LG-VM701 using Tapatalk 2
Did you wipe and format everything but the SD card?
Did you reboot the ROM at least once? Did you overclock yet, and if so, to what settings?
Note: Try going back into recovery and wiping cache partition and dalvik cache.
Are you using WiFi or 3G? If 3G, they could be re-perposing the tower (working on a 4G upgrade).
Note: If still slow, restore backup of ROM with last known working PlayStore app. If that doesn't fix problem, then there working on tower.
Guys i get stuck on the android boot screen any ideas? ive tried different recoveries and multiple download zips.
First for 2014!!! Hahaha... ;)
Seriously, I had to track this down. AndyOpie150 says this is the best Froyo rom. I trust his expertise, and will try this soon. If I get bored of it, I can go back to Mirage sometime. I have the Titanium Backup files for that one. I just TB'd my Harmonia 1.9 apps. Will make a nandroid, send backups to external HD, clean things up, then flash Resurrected Bumblebee. I'll use the vanilla version, as I like my phones lean and mean!
Then I'll decide whether to use my Kyocera Event as a wifi only device for a while. :D
Sorry bout that, I should have pointed you in the right direction. When in doubt, allways look in the All Things Root Guide sticky. I try to keep all the stuff for the V in it.
That reminds me, I need to put bigsupersquids KitKat ROM in it as well now that it is out of the alpha stage and almost out of the beta stage to a WIP.
witnessloc11
