[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
I'm on build 4...to flash build 5 can I just wipe cache /dalvick cache ?
-Sent From My Blu Kuban Themed Tapatalk Like A Boss
I would say, 7zip hero because you're a hero to everyone on these forums. Please share all of the PM's and how you contributed, I would thoroughly enjoy to read them all.
On topic.. when will the bootloop issue be fixed?
Why are you interested in "when the bootlooping" will be fixed? Im just a "kangaroo".
To be 100% honest I have NOT contributed ANYTHING to either sbrissen nor phantom. Ive been a selffish butt hole. Like I said I am trying to mend bridges.
Reactions: deakelem
Re: [ROM][Sprint][JB][08/21/2012] Jellybro CM10 [Nightlies]
Hehe, you said butt.
Reactions: Dark_Knight2
I have 5 running with 8/10 gapps. Had to select allow on superuser prompt before Su would update. Running well. Still having trouble with rotation. Gonna wipe dalvik and cache.
had same issue with rotation.. even went back to stock ff18 and rotation was not working.. i thought my gyrosensor thing was messed up. but then i fixed it by going back to DK's stable 4 version of aokp ics and calibrated the sensor in that rom and it works fine now.
The calibration tool in the stock ff18 tw rom did not help.
Hey Thx! I'm happy to flash anything! Appreciate it. Thx for the heads up on the kernel DK. I saw it once I got installed
cool, let me know if you need a link to the stable 4 build of aokp ics
Wish me luck on my first flash into jelly bean territory. See you on the other side.Thanks dk
Sent from my SPH-D710 using Android Central Forums
and brick!.. :(
jk good luck, its awesome lol :)
No prob other than rotation. Battery seems really good as well just have to get rotate fixed or I'm gonna go crazy! Can u post me a link for ur aokp ICS ROM. I've tried everything I have but no luck. I was told its been used to fix. Thx DK
no luck fro me did a clean install and got set up wiz error and it froze had to remove battery
Status
xembdttxllink
