[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [ROM][JB][08/11/2012] CM10 Alpha18
I suggest closing the thread for 24 hours for testing then post the update if you think its ready to be released.
I'll agree with Dark Knight on this one by saying what good would closing the thread benefit?
Also, Dark Knight or any member don't have the power to close a thread only Moderators & Administration have that power.
Reactions: Dark_Knight2
Paul has the power! He-Man
:P
Okay, Alpha 19 report.
No LoS as of yet *Sound of knocking on wood in the distance*
Camera app is present, but states cannot connect upon opening.
Other then that, still working thru things. I have like ZERO service in my house, so it's a good test area, I'm going to disco my Airave and see how I do with LoS.
Will post back ASAP.
UPDATE1 : Lost service immediately upon unplugging Airave, however, this WAS NOT LoS, it was just a bad signal, I moved 4 feet, resent and it went right thru.
UPDATE2 : WiFi will not turn on, stuck at "Turning Wi-Fi on."
My results
No LOS
3g is finicky after switching from wifi
gps locked in 5 secs to 6 meters
wifi works fine
market works fine
Setting fc's is app, storage, ...more network settings, torch is absent
Running spu spy be back with results for deeps sleep
no wake locks
sms
calls
bluetooth except for media
google now
battery life seems to be decent
anything else?
confirmed exactly about the camera as posted above.
there was a status 7 error on install
take that back about battery... im at 75 % was at 93 % 1 hour ago.
logcat on issues dkhttps://www.dropbox.com/s/wwkp985jyxg0793/logcat812.txt
Also: No root access
Going to reflash and see if I can figure out my lack of WiFi. Thanks for confirming that it is working for you!
I rooted my phone, if i install cm9 will it delete my data that i have on the games that i play ?
Sent from my SPH-D700 using Android Central Forums
My results
No LOS
wifi works fine
market works fine
no wake locks
sms
calls
google now
anything else?
Hey, check your PMs
Back it up with Titanium Backup or ROM Toolbox or something similar and you won't lose your data.
Reactions: icewater106
Also , in addition to the first post of issues, the rom is not recognizing an sd card.
internal or external....
Ok thanks i have titanium back up do i back up all user apps or all user apps and data ?
Running a Euroskank CM10 kang on my Nexus 7. They do good work.
so ive heard
and i tryed to port my self with no luck stuck at sammy screen any help dk?
u help me i help you
Re: [PORT][2012/08/11] Cyanogenmod10 Alpha18
This is really a good find ! so there are no issues with sms , mms, browsing or anything with the USC apns? just curious.. and if this is working maybe it would be possibe for DK ( or someone with the knowledge to do it) to work back from the USC build and make only the needed edits to sprint apn and info .. such as it changing the model it says your phone is and carrier name,, and see if that would make a sprint branded build that works as well as the USC
its not the apn that you edit its the build.prop for it to say a certain carrier and device model number it is really easy to do this.
Status
karanjilka2
