[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [ROM][PORT][08/13/2012] Jellybro Euroskank CM10 [Nightly]
flashing rc1.5 then wiping all but system then the rom messes up wifi
lovin the boot animation so far very smooth
is there a way to turn off the hard key lights used to be done under advanced?
whats screen candy
whats screen candy
Yes id also like to know what screen candy is...it just crashes my settings app when tapped..
What is the exact chris4g kernel I should flash this with there are so many?
Yeah I'm also confused. I just need to figure out which kernel to flash beforehand, I'm already setup on EL29 ready to go.
Epic performance DK, best build yet. I think soon you'll be ready for "beta" lol its freaking stable... anyone that tells you otherwise has no idea what they are doing with this. How in the hell are you guys not seeing the camera app?
Reactions: Dark_Knight2
How exactly do we flash the cwm6? I downloaded it as a .zip file so i just flash it through cwm? sorry very confused D;
dk u got the camera working just how i got it to work through that port
but mine had battery lose problems and i still have los on ur port and my port
ur rotation works mine didnt i didnt have time to look in to it more
and one more thing
the nightly builds now is there any difference from the alpha 18?
im trying to see the los and battery drain in kernel but im not sure how to open the kernel the right way
what should i use thanks
BTW great port u got ur self there
DK, uhmmmm i got the status 7 error and then installed the gapps but cwm never asked me to fix the su binary.. so is that an issue or what? i dont know whether im good or im stuck lol
EDIT: now i feel like an idiot cause i went to reboot and fixed the su binary but now it wont boot into the rom. i just get a black screen after the boot logo :/
Because its not in the app drawer. The camera works if you launch from lock screen.
Sent from my EPIC 4G Touch!
Status
joelkmason
