comptonhubbard
- Jun 14, 2012
- 160
- 17
- 0
Re: [ROM][JB][08/18/2012] Jellybro CM10 [Nightly 3]
Nevermind I think I got fixed.
Just because this isnt "Sourcebuilt" doesnt mean its not going to work. I think ive proved that ports can be just as stable if not more stable. You do not need source for stability.![]()
Of course, the advanced settings are grayed out (I know they are for the nexus S). And in "Performance", you cannot change the minimum and maximum clock speeds (I never do, but I'm just reporting).
The big problem is the camera. It is very laggy in performance and the quality is not good at all (for video recording). Also, you cannot change the size of the video (720, 1080, etc...). Though the "Funny Faces" are working perfect, hahaha...
keep getting a FC on youtube
I'm sorry I was not saying that this was not stable. I was just saying that since this is not CM10 source, it is getting the BT media fix from a different pool of code. In many cases the first builds are leaks and generally more stable at first.
I really see a new build of a newly released version of android built from source and fully stable in comparison to a port that comes from a stable build.
Ok my mistake. Got a dozen things going on.
No worries, I see where it seems like I may be baggin on you. With all the haters you've had at this point, I dont blame you for being edgy haha.
The rotation is really smooth. And for the YouTube application, it's working well for me. It did try to force close on me the first time but then I played a lot of stuff and even in HD on 4G...
Ok so rotation issues are gone. Good s***
Hmmmmmm ok ill look into that as well
Come on man. Where is the next build? You have to give me something. I didn't go to work today, you have to take this opportunity. Today, I'm a flashing maniac...
Patients GrasshopperIm zipping it now. Bout to upload.
