[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Adrynalyne, since I see you take requests, would it be possible for you to create a patch to add the default Clock/Alarm back to this? That is the best alarm out there and I was sad to see it was replaced in this build.
Thanks for all the work you do on this stuff :-)
Major weirdness in 2.6 going back
I am back on 2.4v as 2.5 and 2.6 have major bugs. Ring tones not named correctly in 2.6. Plus 2.5-2.6 is a mashup of two diffent roms.
Try the dummy kernel. It's working fine for me. And turning off GPS definitely solved the sleep problem. Went from 100% running to 7% running.
If you could list the major weirdness it would probably be more helpful to future development or get you help on user errors. My problems are usually the result of me doing something stupid.
There's always the off-chance that it got mislabeled. But unless he's changed it since I downloaded it the other day, it should be good. lol
Status
Cheezy313Bby
