[ROM] t0ast3d de1ight - battery saving/fast/custom look 7-19-10
hey toast, im having issues installing the rom. i cleared data and cache and then flashed. it starts installing and quits in like 3 seconds. do i need to delete the /sdcard dir since my sdcard is that dir? would that help? do you know of issue like this?
Are you installing using rom manager? If not, download it from the market, flash the recovery and install from sd card, should work like a charm
Yeah, put it on the root of your sd, not in any folder
jsut dl'd ver 2 now and gonna play with it to see how it runs.
Is there a noticable difference in going with the kernal 1 over not flashing the kernal?
Im leary about the overclocking function to be honest.
Input?
Input?
Don't flash the first one flash 2
Some report the touchscreen doesn't work on 1
it will increase speed and fix the fps
sorry for the NOOB question, but do i install v2 via rom manager or do i reflash my phone and install v2 like a rom?
found out last night while trying to change a serpentine belt on a friends car that IncrediLight no longer works after i installed this ROM...dunno if it is because of this ROM, the Kernel or possibly neither one of them but i've tried different methods from battery pulls on the phone to uninstalling and reinstalling the app...i get "Sorry! This application IncrediLight (process com.prozach.IncrediLight) has stopped unexpectedly. Please try again." and no matter how many times i try again it doesn't work lol and the light for the video camera doesn't work either but camera flash does
it's not really a big deal to much...just wondering if anyone else is having the same problem...
I found the kernals on XDA I believe but didnt flash them.
All the functions worked and apps I had that I noticed, but appears to be a big battery hog. (unless this has to do with antennas i was flashing to older versions causing it to kill battery)
I didnt give it long to prove itself, but honestly didnt feel any snappier then the stock build. Just removed bloatware. Maybe with a kernal it woulda been better?
^Trippin^
maybe its the diff antenna versions I flashed then causing it to die quicker or just me not giving it enuff time and tinkering with it too much cuz its a fresh rom?
Hey t0ast3d -- you never did share what was and wasn't done by you with this ROM. what work was Hero_Over's and what work was Beezy's. Were you gonna do that?
For a flash light, use TelsaLED
shahg
