[ROM]TeamVenum-Wicked Sensation JellyBean V 3.0 [MB1] ROM
Status
Not open for further replies.
Re: [ROM]TeamVenum-Wicked Sensation JellyBean V 1.2 [OFFICIAL] ROM
None really. I will try to get stuff added this weekend. Trying to get PC running or I would've already had it done. Thanks again for helping.
One slight issue with Anakonda, I have a pink "Downloaded Apps" button in my App and Widget drawer. I've never flashed the pink theme on this phone so I'm guessing it's just an oversight? My home screen app button was pink also, but I used the venum launcher :P
Dazed has a broken computer. He still has work to do. It isn't complete. He released it now because he knew there were a lot of folks waiting for this.
I forgot to do twlauncher. Use apex launcher and you won't see any. Still uses the tw launcher morph from the pink theme. :eek:
Here are the Wallpapers from the original Anakonda Rom from www.teamvenum.com:
I will be waiting until TW is ready...but so far it looks awesome!...I leave on Tuesday for my trip so my fingers are crossed that all bugs are fixed and it is ready to go by then. Thank you guys for your hard work!
There's no bugs. The tw launcher has the wrong theme is all that is wrong.
Oh I am sorry that is what I meant....I only use TW.....
If I use TWRP to flash the Anakonda theme do I still need to wipe cache/dalvik or does it do it for me?
skunape... I still get an error when installing new apps... wat else can I try? Should re-install the Lj7 firmware?
this is driving me nuts... thanks
I think I would try a factory reset.
if i perform any app backup and nandroid, will it be there once I'm back from factory reset?
Any nandroid you will make will bring back any of the issue you are having now.
App backups from titanium should be safe from a simple factory reset. As long as you don't format anything. When restoring apps, only restore the apps and not the data (except for very important data such as checkbooks). The whole purpose behind the data reset is starting over and clearing the issue. Restoring everything will just restore your headache.
so instead of the reset, go with reflashing of 1.2 rom.. from this initial page correct? and when I do that should i also install the LJ7 firmware as well?
This will fix the TW Launcher for AnaKonda theme. Just download and flash in recovery.
AnaKonda TwLauncher Morph - CLICK HERE
Will that ^ be in the updater or do I need to do it off of here?
Skunape, thank you for all the info and clarification...
- - - Updated - - -
oh also... is there an app or what better way to move apps to SD Card?
Status
Autofresh
