[ROM]TeamVenum-Wicked Sensation JellyBean V 3.0 [MB1] ROM
Status
Not open for further replies.
Re: [ROM]TeamVenum-Wicked Sensation JellyBean V 1.2 [OFFICIAL] ROM
yeah i install the ICS version.. im trying to install the v1.2 full rom right now.. hopefully it will work this time.. thanks for all your help.
i did reboot on recovery but its just stuck on samsung logo.. i downloaded the v1.1 .. then when the kuban updater didnt show i install the update version for wicked v1.2.. everytime i install the update zip files it wont pass the samsung logo. but when i install the v1.1 it works fine except the kuban update app is not there
Turn your phone off by pulling out the battery. Press and hold volume UP, power and home buttons simultaneously. As soon as you see the word Samsung on your screen let go of all the buttons. In about 10 to 15 seconds your phone should not into recovery. What version number is your recovery?
That's what caused your bootloop. If you were on the ICS version then you flashed an update for JB it will definitely do that.
right now i restore my phone then ill install the full rom v1.2
Skunkape60 re-downloading it fixed my problem Must of been a bad download the 1st time
i will.. im just waiting for the files to finish downloading :)
Do you still need to manually wipe cache/delvik if you are using TWRP to flash a new theme or will TWRP do it for you?
Does anyone know the mod to get your phone to charge faster? Is it safe?
When talking about a mod like that it is best to post a link to the mod... There are several and would need to know which one you are talking about.
yay it work.. got the wicked sensation rom running on my s3.. thanks for all the help.. im loving it :)
wicked rom have wifi tether right? how do i use it? do i have to download anything to make it work?
This probably isn't rom specific, but has anyone noticed that the lock screen wallpaper is always a bit lighter once you apply it? Is there a setting for that or a way you make it look more like the picture?
I spent forever figuring out this stupid problem...not a lot of people complain about it lol but it bugged me forever on JB. It's the ripple effect, just go to your lock screen settings and disable it.
Update.. so far looking good on restoring the apps from titanium. Flash the 1.2 rom after wiping cache, davlik n reset.. been able to install a couple new apps without trouble.
Thanks again for your valuable piece of information.
Re: [ROM]TeamVenum-Wicked Sensation JellyBean ROM
Getting following error message when updating google voice: "package file was not signed correctly. uninstall the previous copy of the app and try again" how do i uninstall it since i dont have that option. Same goes for google search
Status
Rohit
