[ROM][TH3ORYROM]A05PTH3ORY V1.4X [AOSP/CM7]DKSM Kernel 8/14/11
Reactions: tfrank10
Re: [ROM][TH3ORYROM]A05PTH3ORY V1.3.1X [AOSP/CM7]DKSM Kernel 8/11
Gracias...
:) I need all the help I can get sometimes.. trying to keep up with all these OP's... for real, i appreciate it
everything working ok i guess, only issues i have are the navigation there is no icon to speak into now i can only type in the addresses with the other roms i had the option of speaking, no weather app installed like the other roms, and not much of a selection on ringtones, other than that its fine, maybe it's me but i really dont see much of a difference with this rom compared to the other roms they all pretty much have the same stuff in them.
You have to install the Voice Search app from Google on the Market to get that feature. The weather isn't that big of a deal, just DL whichever you want from the Market. If you don't like the ringtones, make your own! That's what I did and I get to hear one of my favorite songs when people call. :) This ROM (IMO) seems more fluid and less laggy than Sense ROMs. Also uses a lot less RAM!
Reactions: panitsos
Found a problem with the ROM (was hard to do, because this one is awesome!).
In settings, when I go to CyanogenMod settings and then System, I can't choose any 3 of the options. I get the message: "Sorry! The application CyanogenMod settings (process com.cyanogen.cmparts) has stopped unexpectedly. Please try again." Then I have to force close it. :/
Had this same problem. Hoped the update would fix it but no go.
RangelS25
