[ROM] TrulyEpic Rebirth v1.5 AC - no planned EB13 update :'(
Quote:
Are you using an EXT4 filesystem? If so reflash the ROM and do not restore any backups. Then re-test for these issues.
I did the steps to convert to EXT4 prior to installing the ROM. Is there a way to check?
The first time you boot into CWM3 (power off then volume down+camera+power) after running the root, it'll take care of itself. Once done, the text will be orange. Takes 5-10 minutes for it to re-align the filesystem.
Not to mention the fact that I don't think this ROM will install without being EXT4... So if you got it to install, you might already have your answer, but someone else will have to verify that.
As mjbelknap says, you're good to go. Wipe in Clockwork as stated in post #1 under Downloads, and reflash the ROM.
Reactions: Kikoshi
Thanks ragnarokx and others for this ROM
I just wanted to say a big THANK YOU to ragnarokx and those who helped him with this ROM. All your work is greatly appreciated!
Google Talk missing!!
Installed this as my first rom. However, when the flashing was done via clockwork, google talk app was gone. How do I get it back? Thanks!
Soo I flashed my epic...this is my first run at installing a rom. I really like it. However I noticed my phone doing that bootup loop but it was only while my phone was about to die....but is it normal to show it booting up every ime I turn on my phone and will it always ask me to sign into my gmail acct?.also for some reason I can't sync my .live acct....it recognizes it butwont load any emails...was jus wondering if this was normal or should I re flash...sorry about the noob questions lol
Hey man I also get the same deal when my phonebatt ran out constant looping I wuld like to know too about this :)and also my phone goes thorugh logging into my gmail account and mny of my widgets force closes too as if the settings never saved. Basicly they look as it. Was a fresh start
Yes I have seen this happen with my wife's Epic. She is good for running her phone dead almost every day. I pick it up and it says 6% on the battery meter and she complains my phone is freaking out and shutting down on its own... Throw it on the charger and its perfectly fine.
Reactions: Kikoshi
What up!!! quick question, any way to add custom dialer? if so, how would i go about it?
Find one you like that is CWM 3.0.0.5 compatible and flash it in ClockWorkMod like anything else unless otherwise stated. There are a few floating around, some Gingerbread style dialers and other custom colored dialers.
I thought about adding one in when I did the Mini Theme v1.5 but I felt leaving that option up to you the user would be a better route since not everyones taste in colors/styles are the same.
Cool man, I just gotta find them huh. Any suggestion as to where to look? And Ragnarokx helped me get started so i could start making themes for myself, would you be alright if i turned to you when i get stuck?
Dialers <-- A few here with other add ons. Look on the right hand side of page. ptfdmedic, creator of the midNIGHT ROM.
I'm new to the theme making business myself but I have a relatively good understanding now of what is what and where inside the framework. If there is something I can help you with I will most certainly do. I'm not much of a graphic/painting genius so thats my biggest hangup when designing themes. My best suggestion is do a lot of research and don't be afraid to ask the pros like over at XDA. I went to them for some help on the Mini Theme v1.5 and they responded in a very timely manor with the help I needed.
im guessing the problem was the "edify" part huh. i tried same one a few times never work till now.thanks! now last question for the night, for boot animations, do i need to look for specific "edIfy" ones? I honestly dont like the "blue nexus S". im retrying one at the moment (just downloaded stright to phone) but the first time i tried it did not work... =[
I was wondering what the differance is in the browser that's in the rom and the stock dk28 browser.
Yes anything you run on CWM3.0.0.5 has to be Edify ready if they are flashed.
http://www.4shared.com/file/EU9sDtxW/LiquidLiveWallpaper_13.html
Alright but have you found yourself having to reflash the ROM frequently because some bhhow after restarting the phone the widges looses their setings and are erase on the screens? As we'll it FC's before that happens? And unussually I find my self having to re eneter my gmail accunt after clicking Loid "greenandroid" because sadly this is hats been happening to me. Unless I screwed up something.
Also to save on posts do I gotta reinstall the modem everytime I flash a new or current truely epic rom? Ty just wante to mentioned that is just weird that im doing this :/ im sure I might have messed up somewere
No I haven't had to reinstall things or reflash any roms. I have seen her phone have FC's or start running strange and I've blamed it on her battery being so low that it just can't function anymore. I have her Epic running EXT4, Bonsai 1.1.2 I think is the version.. Its right before everything went to Edify script and CWM3. It runs great as long as she doesn't run it down to almost dead.
Weird then, but i was talking about the Rebirth Version Rom, didn't know she was running Bonsai.
Thats okay... No I personally haven't run my phone down that low to see if there's any issues with the battery being low and causing FC's. Honestly TrulyEpic Rebirth and the original TrulyEpic are solid performers and never give me any troubles. I only had 1 or 2 FC's during testing for Ragnarokx in the Beta version.
Reactions: Kikoshi
Think I found a bug or maybe it's just my phone.
Widgets disappear when moving an app to SD card.
Noticed this with the following programs today, Pandaora Radio, Audiogalaxy, Where & Evernote.
Started off by looking for the Pandora widget which I used before and it was not in the widget list to add. I opened the program and it worked fine. I then noticed Audiogalaxy's widget was not on the list. I did not think much about it at the time but then Audiogalaxy had an update today and after the update the widget was now back in the list. Now I thought something was strange. I uninstalled Pandora and reinstalled it and the widget was in the list. I added the widget to my home screen, moved the app to the SD card and the widget erased from the home screen and the widget list. Looked down my list of installed programs and realized Where and Evernote were also missing widgets and the common theme was App 2 SD. I did find it interesting the widget reappeared when Audiogalaxys update was installed while the program was already moved to the SD card.
Anyway I am not sure if this is related to the file system change, a DK28 issue I never noticed before or something else, I did not see anyone else mention this and if it has already been covered I apologize.
Gordo52
