[ROM] TrulyEpic Rebirth v1.5 AC - no planned EB13 update :'(
Wow I'm the only one who has encountered this issue?! Amazing... :(
I Think i know what you're talking about and i experienced something like this yesterday, though i restarted the phone and everything went fine.. is weird.:-\
Call log/history
OK, I thought I saw this discussed but an not find it. I thought that my call log prior to rooting and flashing this great ROM, would only show phone calls and did not have sms messages in the list. Is there a way to have the call log show only the phone calls (meaning I want to see dialed, received and missed phone calls). I see where I can pick one of the above or select all logs but when I select all it incudes messages sent and received.
Thanks for all the great info, this by far is my favorite ROM and all is working great.
Problems with adding to contacts
I am having a problem with adding a contact from the call log. When I press on the number it pulls up a screen with an add to contacts button on it. When that button is pressed it goes to contacts list and not to the contact editing and saving screen.
Any ideas? or fixes?
Thank you
Try installing the Restore Bubble SMS from the first post in this thread. I think that resolves this issue.
compass not working!!
just downloaded this rom and it is amazing. save that my compass is jacked. apps like skymap will not detect where im facing. please help!!
my gps works great, gets a lock and is accurate. just cant tell which way im facing. figured this was an internal compass issue. actually had to use that link to get my gps working. i did step 4 and now it works. just still have said issue
Long shot.
Menu - settings - display - horizontal calibration
Another idea is the bubble level app, I think it has a calibration tool.
Reactions: prometheus1983
good idea, tried it about an hour ago. thanks though. might just flash to stock dk28 and see if it persists. then go back to 2.1 perhaps. thought maybe someone else had this issue. appreciate the help guys
I know the Sprint apps are restorable from the first post but since I want to keep the bloatware to a minimum can anyone pull the sprint navigation app out of those as a standalone? It the only useful one for me and since I get it free with the plan is partly useful. I would send you cookies :)
Thanks for the suggestion, but that did not work for me. The sms sent and received are still in my call log. Still searching for a solution.
I have a copy of the Navigation .apk, don't know where I got it, but its stand alone.
I don't know how to post link, so if someone tells me, I will, or if you pm me I will see if I can send it via email to you.
I was in old Truly epic. I followed the instructions and moved to truely epic rebirth. I face some issues like phone changing to roaming and turning off and restarting. And phone not charging. I have to switch off and on again for proper charging.
I was in DK28 and and Truely epic. Any suggestions ?
Sprint Navigator.apk (install directly from SD card using Astro or other apk installer equivalent. DON'T FLASH IN CWM)
Reactions: Grays
Is there anyway to turn the WiFi Status feature off.
Thanks!
Are you talking about the WiFi Status icon that pops up? Little black icon with red "X" threw it I think?
If so, I will mention it to Ragnarokx see if he has a revert option that can be flashed.
That is indeed what I was referring to. Thank you!
It should see it still. EXT4 has nothing to do with changing Windows from seeing your phone.
Try reinstalling your Samsung drivers.
Reactions: mlpomer
MatthewD
