Well, it's taken me a while to get this rom really working well on my epic. Went through two total failures with 1.2. After reading through this entire thread the one common theme that kept hitting me in the face was trying to restore all of my "stuff". Saved settings and the like. Letting the setup restore my apps was fine, but I kept trying to restore the settings, etc. Finally on the third try I just started over, let the setup install my apps, then set them up individually after that with no restores. Finally a TER 1.2 installation with no problems. Then flashed 1.5 on top of that, fixed the email and wifi problem from the first post and this thing just flies.
This epic finally works like I always thought it should. For the first and only rom I tried I'm not surprised that I had a few hiccups. Instructions? Why would I need instructions? oops. That doesn't mean that I won't add something or do something later to break it however. I like to tinker.
Side note, my battery lasts much longer in 1.5 than it did in 1.2. Was there significant improvements there? I didn't see anything like that in the release notes. Or is it just because I did it clean the last time? Stock battery lasts all day now, the extended battery lasts just over two days with some pretty heavy use.
Thanks for an excellent ROM.
