desibrainiac
- Jan 28, 2011
- 2
- 0
- 0
I do like Mini Theme 1.7, however, I do not like the Black Dialer. I thank you for all your work but is there anyway to revert it back to the regular dialer?!
I tried moving my memo from samsung stock apps to system/ apps then rebooting and nothing is there. So I tried other samsung apps and none of them are installed after reboot either. So I then tried clicking on the file while still on the sdcard without moving to system/apps and it will let me install some of tha apps that way. I'm trying to get my memos to work. Not a big deal just trying to get it to work. Everything else with ter1.5 is working great. Did the auto backup version. Runs faster than before. Thanks
Just wanted to say, after using this ROM for the last couple of days, I would be happy if I never got to flash another ROM again. It's significantly more responsive than TER1.2 (which was already snappy), and my battery life has been noticeably better as well (at idle I lose about 4%/hour instead of 5-6%/hour). Thanks for all your hard work Rag & Paul!
I just wanted to ask a quick question.... was apps2sd built-in to this ROM? I believe I read earlier that it wasn't. I'd like to free up more space, as I'm running out of it....
Apps2SD is a froyo feature, which would make no sense removing it from TER, so to answer it, yes it comes with app2sd![]()
Yeah, I realized that. With my evo I was running Cyanogen mod and I could move some of the apps the developers didn't enable for apps2sd to my sd card. I had my card partitioned and didn't know if cyanogen's feature was in this rom as well because I read earlier of someone who had partitioned their card too. I was only wondering why they would partition it when apps2sd is enabled via froyo anyway. Guess I'll have to slow down with so many apps now....lol![]()
I just used Root Explorer, moved memo.apk and myfiles.apk to /system/app - they immediately showed up in the applications list and are fully functional (didn't even reboot).
What file explorer are you using? Did you double check that the files were successfully written to /system/app ?
Thank you!
Go to Settings>Applications>Manage applications>(app you want to move)
If the app has it enabled, the Move app to SD button will be lit up. Press to move.
i downloaded the epic rebirth file from one of your links and placed in on my sd card but when i try to find in in clockwork recovery i cant find the epic rebirth file?? plz help.
Or buy a bigger sdcard![]()
I used es wich was included with the rom and I copy memo.apk and past it on the phones system/app and when I open the folder the memo.apk is there . If I click it is says there's An error parsing the file. Exit out or reboot and it just isn't installed. Unless it ain't copy and pasting correctly with es . I can't find an option to just move the file so I copy and paste
