Nope, that didn't work. Removed Sprint Installer, rebooted, immediately asked me to upgrade. Of course, I cleared it off. Get some rest.
You had installed the update manually also right?
maybe a logcat can tell us what runs ota and how to kill it
You ask and you shall receive.
Try this one instead, check out PID/thread 2034
A little more than halfway down:
D/vending ( 2034): [10] DeviceConfigurationReceiver$1.run(): Clearing cache in response to android.intent.action.SIM_STATE_CHANGED
Wow zefie... I didn't even realize you have made multiple releases in such a short fashion... I am still running v3 with my Gingerbread theme (since it is black)...
Some comments/questions:
1) Could we use custom build props from Thunder for this? I see wifi.supplicant_scan_interval is still set to 20. The new props have this set to 60 to save power. If we cannot use old props from ThundeROM, consider implementing this change?
2) Could you move the Sprint Zone apk out of system? Easier to remove that way.
3) Does the battery icon show percentage remaining like on many of the customized themes? Just curious
4) Does updating from v3 require a wipe on anything? Or does your update script handle this? Like the removal of IQAgent, etc... Thanks.
@zefie
If your testing for 007, do you have 006 to release, with the possible fix to the nag. Anything is worth a shot.
Flashing now...
The OTA harassment is still there, but love the Nexus boot animation. Here is a LC, in case you want it for troubleshooting the OTA.
EDIT - This was flashed on top of 005.
Do you think you could tie in a reboot, and a reboot into recovery option like LEGO did? In a future build...
Quickboot on market will cure your fix
