raymix1000
- Dec 24, 2011
- 159
- 13
- 0
id like to test
looking forward to it. might i suggest the following:
a) reboot and recovery in the power options menu
b) TV off animation
Tv tv off should already be included![]()
Reboot and recovery options are last on the list to include as a mod because it is a little difficult to add manually im going go focus on the easy to add mods first![]()
I've been able to successfully add reboot and recovery options to my Optimus Q and could probably easily do it for the Slider. Let me know if you need any help.Tv tv off should already be included![]()
When I press the power button nothing happens
The CRT off animation still isn't there. I like the progress.
Change that value to false in the bools and then comment out debug.sf.hw=1 in the build.prop (#debug.sf.hw=1) then ur good.
Sent from my LGL55C using Tapatalk
