ARCHIVED: [ROM][WIP] Unofficial CM7 (Gingerbread) - 8/19/2011
Status
Not open for further replies.
@ath3nos
I noticed you removed rom manager from the build which is a stock CM apk (afaik) but left in FM. Might want to pull that.
Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - 7/9/2011
For some reason, I'm not receiving MMS. Someone sent me a pic, and I pressed "download" but nothing else happens. And this is on a 1 hour fresh install of this ROM. Would appreciate help!
Edit: Apparently I can only see MMS when I enable 3G and not Wifi. Is that normal, or did I just miss it from before?
Thats normal. MMS uses cell data.
Ok I am going through an issue...I'm not sure if it is just me but on every call whether its incoming or outgoing my voice has a delayed echo. Every single call. Almost making it unbearable to even make or take calls. I have reflashed the rom 2 times. Once dirty and once full clean. Same results while in call. I flashed reborn rom and it stopped. Assuring me it is this specific rom. Does anyone know what could be the cause?
Sent from my Optimus Prime
@ath3nos
I removed ROM Manager because it's poorly written proprietary software that doesn't work well on HVGA devices. If you want it you can download it or buy it (but why bother?). I added the FM app because getting the FM radio to work is on my list of things to do (presuming it can be made to work with the thunderc phones).
AFAIK ath3nos hasn't changed the included software set from what I've picked (yet).
Blarf - any clue what may be causing my issue?
Sent from my LG-LS670 using Tapatalk
I hear you. Stupid me has to compile all over again because I forgot to sync and all I ended up doing is wasting 3 hours compiling the same build as before, lol.
You can typically get away with an incremental build. Config file changes tend to require a full build tho.
How would I open an issue on Github? I'm new to the whole dev thing. Would it be at the Cyanogenmod Github? I know how to navigate through the site to post it but where exactly? Also wouldn't someone else need to confirm this to make sure it's not just another problem with my "hacked up" builds?
CM uses google for bug tracking, open an issue here:
http://github.com/inferiorhumanorgans/android_device_lge_thunderc/issues
Feel free to verify on your own with a not hacked up build (or solicit someone else to build a ROM). I haven't seen that issue but I also haven't done a factory wipe.
Does anybody have any suggestions for me? I would really appreciate it as this is very frustrating!
Start by explaining what exactly (aka in full detail) what you are having issues with. Nobody can help you if you don't tell what you actually need help with.
Sorry you must have missed my initial post...here I've copied it even though its about 5 posts up....
There is always google voice which is much better than sprint voicemail.
Google Voice is a GOD SEND!!
Now if people call my Sprint number, it don't matter which phone I'm on ( I can even pick and choose up to six different numbers ), I will get the call.
I couldn't go back to Sprint's VVM if I tried.
Also, Sprint's VVM doesn't like to play with Gingerbread, so Google Voice is definitely a better option.
Reactions: markcox87
It's better then Verizon wireless voicemail system too. I don't have to worry about forgetting my password or even listening to the message with the Google voice to text widget.
Sent from my SCH-I500 using Tapatalk
@ath3nos
This is a compilation of blarf's github. I'm not sure why he excluded rom manager and kept FM. At this point he is really doing all the work. I'm just compiling for everyone to use. I'm going to be working with nick to get s vanilla gingerbread rom. It might take us awhile, but we will be working on it soon.
Edit: just read that blarf already answered, lol.
I noticed an echo while on a call today too. Only on my end and only when I talked.
Also only on one call that I've noticed. Other calls were ok. Also happens to be my last call. If problem persists ill look into it more
Exactly. The person I was speaking to did not hear anything...I'd sure love to find a fix for it. Any ideas dev's?!
I've heard the echo. That usually has more to do with your current cell tower connection rather than the phone itself. It will change based on location ... I've noticed it on other roms too.
It has occurred in multiple location that have previously expressed excellent connection. I live in Atlanta, Georgia. Theres a cell tower ever 50 feet LOL
I'm curious. I have had this issue a few times myself. However, it only happens a few times and it is always the same people. The connection between all of them is that they are on Verizon. I'm not sure if that means anything, but any time I call a Verizon number I hear the echo. That may or may not be your case as well. Just putting it out there that I experience the problem too, but mine seems to be a little more specific.
don't know if this has been happening to anybody else, but every time I turn on WiFi through the notification power widget my phone reboots itself(it also happens with WiFi Hotspot). Is this rare? or a common bug in this ROM?
Status
