ARCHIVED: [RoM] YOUR-MOM-ROM v.1.1 - Updated 11/27/11
Status
Not open for further replies.
It seems that this rom has an app called "Download all files" pre-installed. Whenever I try to download certain files from the browser like .apk's this app will download them instead of the built-in "downloads" app. The "Download all files" app does not have an uninstall button in the app settings and displays ads and generally sucks. Does anyone now how to get rid of it?
It seems that this rom has an app called "Download all files" pre-installed. Whenever I try to download certain files from the browser like .apk's this app will download them instead of the built-in "downloads" app. The "Download all files" app does not have an uninstall button in the app settings and displays ads and generally sucks. Does anyone now hoe to get rid of it?
Easiest way is to use titanium backup to uninstall it. The free version from the market will work fine if you don't already have it.
I should have mentioned this, but actually I already tried removing it with titanium and then whenever I download a .apk file and click on the 'download completed' notification, it will give me an error like it is force closing the 'download all files' app.. like somehow titanium didn't completely remove it but just broke it.
In other roms when downloading a .apk and clicking on the notification it would just prompt to install the .apk. I just want this functionality back.
I get the option to open with download all app or to install apk.
you could try clearing everything from recovery and flashing the ROM again. Idk if that'll help or not but its worth a try.
A close to perfect ROM but obviously a few bugs in it. So first of all on the notification bar, it fills up with icons and covers the clock.Secondly, don't take this offensively but the boot animation deserves Alot more color and animation basically.You should also add some built in boot options recorvery,reebot,power off etc when you long press your power key. If I find anymore bugs I will be back but this is a nice room
On post 2 of this thread there are extras you can add in to the ROM. One moves the clock to the right side of the notification bar to eliminate the first issue you described. Another adds more boot options to the power key when you long press it (reboot, recovery, etc.). I can't help you about the boot animation. I like it. I have been using this ROM for a while but never noticed the boot animation until I was driving to my in-laws for the holidays and decided to reboot the phone while it was on a dash mount. There, in the middle of nowhere, Virginia, everyone in the car was greeted with YOUR MOM!
Reactions: mike9670 and jstntp
Post #3 is where you can find the extra mods/options to flash.
^This just made my day, lmao!!
Jstntp,
When Nick 7 still had RebornROM v2.2.4, there were tons of custom boot animations that we could use. Do you know if they would work with YOUR-MOM-ROM?
Thanks!
BJ
Jstntp,
Thanks!
BJ
Boot animations are very similar to GIFs: not much more than a folder of images with numerically sequential names; there is a file that contains some metadata on how the device handles them. In flashing boot animations, the only things that you will want to be mindful of are the resolution (MDPI or 320x480 work best on the Optimus S) and the size of the file (internal memory on the Optimus S is kinda limited). If it worked well with any other ROM for the device, it should work just fine with Your Mom ROM or any other.
Reactions: biggjoe
Hi! Just rooted and installed CM7.2 Port for Optimus S by thekraven. However, I was told that ##debug does not work with CM7 ROMs. Can I install YOUR-MOM-ROM v.1.1 over CM7.2 Port for Optimus S by thekraven? Thank you!
Not without upgrading to zvh first.
Reactions: psalm10045
Just installed the new Maps update. It works awesome but it keeps showing my position off. Anybody else having this issue or just me?
kind of a rant since i'm sure its not the roms fault but has anyone else's facebook app been way laggy since they updated to the new appearance?
Status
Tfunz
