[ROOT] [KERNEL] [Repost of jt1134] Root,ANY build w/ Voodoo lagfix!*updated*
Re: [ROOT] [KERNEL] [Repost of jt1134] Root,ANY build w/ Voodoo l
just flashed, but i dont think im getting root i def have vooodoo but i open up a terminal simulator and shows the $ instead of the # tried typing su but says permision denied help?
I am having the same issue, no root. I had root on ED1, flashed OTA EE4 and have tried the CWM method and the Odin method about 20x each. I've gone back and forth between RFS and EXT4 as well trying any combination to get root. What am I doing wrong? I have tried all the methods on Android Central, XDA and Android Soul. I have tried several different kernels. Everything works as described, but I cannot gain root access! My OG Droid finally crapped out on me, (hence the new phone) but I was flashing ROMS left and right with that device. The Charge is getting the best of me right now.
Someone please help, I need power over this thing! My email is my username @ gmail.
Thanks
After I rooted, I see that USB debugging is now enabled. Can I disable it, or should I leave it on?
Edit: Looks like Titanium backup wants it on.
Does flashing this give me a factory reset? I want to root with out losing all data....
will it work after the GB update??
Tfunz
